here we go
Old Aug 1, 2009 | 09:44 PM
struttin's Avatar
struttin
here we go
I sure do appreciate all the info i get here ,Im new .The question i have is I pull a 13000lb fifth wheel. For the first time its begun its puking problem,climbing hills in branson MO. What is your alls evaluation of what i should do. I would like to improve upon performance,but only 30 or 40 hp?
Old Aug 2, 2009 | 09:09 AM
D8chumley's Avatar
D8chumley
Resident smarta$$
Some info on your truck would help, but if it's puking now you probably want to get to the cause of that first and repair it before you start throwing more ponies to it. If you're still under warranty take it back to the dealer. Could be one of several things, including HG's. Welcome to FTE!
Old Aug 3, 2009 | 08:58 AM
Cowboy65's Avatar
Cowboy65
Did you fill the coolant only to the MIN level in the degas bottle per Ford's updated recommendation? Sometimes puking is caused by normal expansion when the initial level in the degas bottle to too high. If you find a more serious problem, after the repair is made you should replace the degas bottle cap.
arctic y block
29
Feb 4, 2015 08:26 AM
frdf250
Jan 23, 2011 11:36 AM
matttomlinson
Dec 8, 2009 05:25 PM
videorov
Jul 21, 2009 09:28 AM
x12secondjourney
Modular V10 (6.8l)
Jun 1, 2004 08:33 AM
