1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Third gear in an automatic
Old 08-01-2009, 08:33 PM
VTX1800rider's Avatar
VTX1800rider
VTX1800rider is offline
In a 06 V-10 350 auto. I went to move the truck in the garage. I put the tranny in third instead of drive where I normally use by mistake. When I hit the pedal it seemed like it started off in a lower gear. I went back to 'D" and it was just as usual. I tried it again in third and it felt like it's a lower gear. Is the first gear lower starting off in third? I've had the truck about a month with no issues.
Old 08-01-2009, 08:37 PM
06silvercrew's Avatar
06silvercrew
06silvercrew is offline
It started off in a higher gear....3rd. If you put it in "3" it will not take off in 1st gear.
Old 08-01-2009, 08:51 PM
QwkTrip's Avatar
QwkTrip
QwkTrip is offline
Sounds like the transmission was obeying your every command.
Old 08-01-2009, 10:00 PM
VTX1800rider
Well it's look like I ended the day with a dumb question.
Old 08-01-2009, 10:13 PM
Mustang6147's Avatar
Mustang6147
Mustang6147 is offline
I dont know that i agree... It isnt a manual valve body... Its the Auto matic, so its the Torqueshift.
I am going to try it with mine tomorrow, and will report back.
I sometimes make the same mistake and notice it when I am driving and rpms are to high. It still starts off on 1st gear though, just wont shift past where I have the shifter.
Old 08-01-2009, 10:42 PM
EXv10's Avatar
EXv10
EXv10 is offline
Mine only starts off in 1st in drive.
Old 08-01-2009, 10:58 PM
06silvercrew
"I dont know that i agree... It isnt a manual valve body... Its the Auto matic, so its the Torqueshift."
I do trans work for a living, have yet to see one that will start off in low gear when 3rd is manually selected.
Old 08-01-2009, 11:06 PM
Mustang6147
This got my intrest... You may be right, I wanna see though. Kinda like when my mom said dont touch those prongs on the plug in the wall...
I had to see...
Old 08-02-2009, 01:17 AM
ford7379trucks's Avatar
ford7379trucks
ford7379trucks is offline
it will always start off in 1st no mater ware you put it. except revers of course. the reason you can put it in a different gear is so it wont go above that gear.
Old 08-02-2009, 02:10 AM
bayou barataria's Avatar
bayou barataria
bayou barataria is offline
Didn't your mama tell you smoking that stuff will make you slow witted? lol.
Old 08-02-2009, 06:49 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Mark Kovalsky is offline
Received 1,606 Likes on 1,076 Posts
That's wrong!
Ford's standard is that if the shifter is in 2 or 3 those are the only gears the transmission will use. In 2 it will start and stay in 2nd gear. In 3 it will start and stay in 3rd gear.
Old 08-02-2009, 09:52 AM
EXv10's Avatar
EXv10
EXv10 is offline
Originally Posted by Mark Kovalsky
That's wrong!
Yep, that's how mine is.
Old 08-02-2009, 10:44 AM
Mark Kovalsky
That's how ALL Fords are designed.
Old 08-02-2009, 11:49 AM
QwkTrip's Avatar
QwkTrip
QwkTrip is offline
I think some people are fooled by the torque converter. It's not nearly as obvious by feel which gear you are in as it is with a manual tranny.
Old 08-02-2009, 12:15 PM
suzuki0702's Avatar
suzuki0702
suzuki0702 is offline
umm yeah i thought this was common sense to most. on my 4r100 put it in 2 and its in second gear no matter what, same with 1..................??????????????????????
Quick Reply: Third gear in an automatic
