fuel pressure ?
Old Aug 1, 2009 | 08:10 AM
03f2506.0's Avatar
03f2506.0
fuel pressure ?
Just finished putting in 3 more gauges, fuel pressure, water temp & volts. One question I have is what is normal for fuel pressure and should the pressure drop some when you floor it? Thanks in advance for any help.
Old Aug 1, 2009 | 08:26 AM
tex25025's Avatar
tex25025
60 psi would be a good pressure for it to be at. You don't want it to drop below 45 psi. There should be a steady supply of fuel pressure, but on the extreme overfueling tunes, you could see a slight drop, but I wouldn't like that even if it is a little bit due to the fact that these beasts love their fuel as much as they love their oil.
Old Aug 2, 2009 | 09:26 AM
03f2506.0's Avatar
03f2506.0
Thanks for the reply Tex. The fuel pressure I'am seeing is 52 psi. Lower than 60 psi but thankfully higher than 45 psi. Does this seam OK for a stock 6.0 with 32,000 miles on it? Thanks again for any replies.
Old Aug 2, 2009 | 09:51 AM
PETE'S_6.0PSD's Avatar
PETE'S_6.0PSD
i get about 50psi on the stock pump when i turn the key on. will see what the drop is. time for ITP RR sooner or later....
Old Aug 2, 2009 | 01:00 PM
69cj's Avatar
69cj
That min. press. of 45 psi is at wide open throttle. Any less and injector damage is possible.
