Sponsored by: Real Truck
Softer Less Bumpy Ride ?
Old Aug 5, 2009 | 06:54 AM
celjel's Avatar
celjel
They don't really just stiffen the suspension, they absorb the shock of hitting the bumps. Running empty I run 5 psi on them but when I hook to our rv I raise them up to around 20 psi. You would be amazed at how much the air gauge for them bounces around even with the truck empty.
The springs bottoming out wasn't causing a rough ride just an annoying noise every time you would hit a bump.
Old Aug 5, 2009 | 04:35 PM
bill11012's Avatar
bill11012
Modular motor junkie
Originally Posted by ssharber
I had the same problem. When I would put 65 lbs of air in my tires, which is what Ford calls for, the Goodyears felt like they were solid steel tires. I could feel every rock or small imperfection in the road, so I used 55 instead, and would only air them back up when I towed something. Then, when my Goodyears wore out, I decided to put Michelins on her. They are excellent tires, and they feel like Im riding on pillow wheels., with 65 all the way around. Now I know why the Michelin Man is a big marshmallow. They are Load range E tires and are excellent in the rain, mud, snow, and dry pavement. They cost more, but they are worth it because I only got 39,000 out of my Goodyears, and I have a friend who has the Michelins on his truck and he's already got 73,000 on them and they STILL look good. Just my 2 cents worth
That is what I did and they are the best tires I have ever had.
Old Aug 5, 2009 | 11:21 PM
JohnD333's Avatar
JohnD333
Originally Posted by LaredoF350
The air pressure that 'Ford calls for" is whats recommended/required to tow and/or haul maximum weights premissable on these trucks. If running these pressures empty your truck will ride like crap and the centers will wear on your tires too quickly from being over inflated for the weight they are carrying!
I second what Larado350 says. Most every tire mfg provides weight/pressure scale fo single and dual applications. If you run your rig onto the scales loaded and unloaded you would be amazed at the difference in acle weights and it only makes senme to follow tire mfg guideline, maybe adding a bit if you want a harsher ride. Otherwise you ride harsh all othe time that you are empty and will wear out the center of tires - probably not noticeable tire war if you carry modest loads most of the time. My reason for pointing this out is I have a Job 1 450 and when it is loaded I need to have 10 pounds OVER the pickup plackcard suggested inflation to match my load. That load is well under weight rating of rear axle, yet pretty close to the rating of the front axle - but not over the tire ratings or max pressure when I follow the inflation pressures guidelines bt tire mfg.
John
Old Aug 6, 2009 | 03:04 AM
ssharber's Avatar
ssharber
Thanks Bill, Crazy001, and all the others here who realize that the manufacturer of the VEHICLE sets the reccommended tire pressure, based on the axle weight, unloaded. As stated in this email I received from an engineer at Michelin, "When your vehicle was manufactured, Ford selected the appropriate tire,
based on the axle weight.
Then knowing the actual axle weights they determine the air pressures of the
tires.
The 65 psi is based on axle weight, does not including any hauling, towing,
etc.
So we have to give you the standard answer..........door placard, anything
lower subjects the tires to overloading and the possibility of sidewall
ruptures."
So Laredo, what have we learned? These are heavy trucks, and as has been stated by MANY here, they've run their tires at 65 and EVEN higher with no problems. Kind of reminds you of the days when the Ford Explorers were blowing out tires because of low tire pressure. These are 10 ply tires and they need that amount of pressure to stand up to the stresses/weights, unloaded, like the email above said. Running anything lower or trying to find a tire manufacturers reccomendation for a certain weight just wont work because they have to factor in what the vehicle axle weighs. There are max pressures imprinted on the sidewall, but that doesnt mean you use that for everyday driving. Class dismissed Laredo, and thanks to all of you for your comments. We all come here for help and guidance, reccomendations, and there's no sense in someone blowing their stack 3 posts down. By the way Bill, have you gotten that hybrid out of your grill? :-)
Old Aug 7, 2009 | 02:30 AM
TigerDan's Avatar
TigerDan
There's no call for the jabs and personal attacks. Keep it civil.
Old Aug 7, 2009 | 07:19 AM
m350's Avatar
m350
Hmmmm Amazing,,a 3/4 ton vehicle's ride is firm !
You should ride in a Older F-250,,say a 75' or so,,,or and older Dodge,,,,Thats a rough firm ride !
My 18" Contis have had 80 psi in them since I drove the truck home over 3 yrs ago! Rather loaded all the time plus towing trailers.
The ride in my 06' F-350 is not that bad comparing to other trucks (older)I have been in.
Old Aug 7, 2009 | 08:19 AM
jdadamsjr's Avatar
jdadamsjr
Have read on here for years how much better Mich's are than stock....
I just swapped from the stock BFG's that I got 84k miles out of (with tread left) to Michelin's and I am really under impressed.....
IMHO, the ride is very similar to the bfg's re jouncing over bumps, etc...
so the tire only has so much to do with it.... after all, load range e's are load range e's
I too adjust my air pressure based on intended usage....
but not having a scale at the house, I use the chalk test to gauge the load on the tires....
When we use the Ex for our trips, I will bring my handy dandy B&D air station along...
Air up for the long interstate rides to 75 or 80 cold (even if not towing)
and once we get to our destination, air them down for the running around on the secondary roads.....
then use the air station to bump them back up for the long ride home
(I fool myself into thinking this will get me better mpg @ 80 - 90 mph keeping up with traffic )
to heck with the .5 drag coefficient !!!!
Good luck....
John
Old Aug 14, 2009 | 04:25 PM
jrandol's Avatar
jrandol
Originally Posted by raysbigfish
how can i get a softer and less bumpy ride on a 2009 f-250 crew cab ?
Air Ride Suspension
See Mine Below, rides like a Cadi Empty and can make it ride level w/ ~5,550# on the rear axle.
Old Aug 14, 2009 | 04:44 PM
bill11012's Avatar
bill11012
That is awesome!
Do you have a thread detailing the swap?
Old Aug 14, 2009 | 04:46 PM
jrandol's Avatar
jrandol
Originally Posted by bill11012
That is awesome!
Thank you! Detailed Swap=Forthcoming. When I get back from this trip (Wed.) I should have all the photos & video organized.
gogoat
Aug 22, 2017 09:54 AM
magum350
6.7L Power Stroke Diesel
Jun 17, 2017 04:06 PM
JoeK.
Oct 3, 2016 02:25 PM
paulmac
Sep 17, 2015 08:54 PM
chunispoor
Jun 15, 2015 10:47 AM
