Sponsored by: Real Truck
'05 Aux button
Old Jul 31, 2009 | 04:37 PM
Willy's boy's Avatar
Willy's boy
'05 Aux button
Have an '05 250 with a single disk factory cd. How do I plug in a aux cable to run my xm? Do I have to pull the radio? My xm goes from work to truck so I just need to get the aux sound in. I have the fm direct stuff. Thanks in advance.
Old Jul 31, 2009 | 06:26 PM
jantman's Avatar
jantman
I have an 06 and looked into this once. I don't know about the single CD, but with the 6 CD you have to pull the radio and install an auxiliary input adapter, as the aux inputs are (supposedly) some special interface to the rear entertainment system (the 6 CD is the same one for the big SUVs).
I'd assume that if the single CD changer has an aux input, it probably requires some sort of adapter to work with a "normal" headphone or RCA cable.
Last time I looked, the adapters were about $80, at which point you might as well just get a $100 aftermarket stereo with aux input on the front.
Just my $0.02.
Old Jul 31, 2009 | 07:43 PM
powerstroke72's Avatar
powerstroke72
You can get a P.I.E. adapter here:
http://www.pie.net/index.htm
They are easy to install. The dash has to be removed and the radio pulled but it is much easier than it sounds. The dash just pulls off....no tools needed. The hardest part is unplugging all of the connectors from the back of the dash. Once you have unplugged everything, the dash just pulls off. JUST a heads up though, the easiest way to do it if you have an auto tranny, is to turn the key on and pull the shifter all the way down into 1 and tilt your steering column all the way down. Also, it is a good idea to remove the negative battery cable. I have done it both ways and haven't had any problems though. If I remember correctly, the radio bolts are 7mm and easily removed with a nut driver. Then you just need to unplug the connectors from the rear of the radio and hook up the P.I.E. adapter.
There's a write up with pics in the SD tech folder at the bottom of the page in a post by Krewat with a link to the write up. It really isn't difficult. I had the dash out of mine a few weeks ago installing a new SIRIUS radio.
Old Aug 9, 2009 | 10:31 AM
Willy's boy
All done. Ordered the radio interface and removed the dash. The tech folder instructions are right on. All went well with no problems. If I can do it so can you. Use the AUX button. Thanks Powerstroke72 for the heads up. This board is AWESOME! Thanks.
Old Aug 9, 2009 | 01:11 PM
powerstroke72
You're welcome and I'm glad to hear that it worked out so well for you my friend.
