Sponsored by: Real Truck
What motor do I need?
Old Jul 31, 2009 | 03:27 PM
Brojon2002's Avatar
Brojon2002
We are looking for a new truck to tow our toy hauler (tow behind). It tips the scales at about 11,000 lb and as much as 12,000 lb loaded for a long trip.
We will not be using the truck that much; I currently put on about 4,000 miles a year. When you're only towing the trailer about a dozen times a year the extra cost of a diesel is a bit much to chew.
Can I get away with a gas motor or do I need to use the diesel? We do have one large pass to cross when we use the trailer.
Old Jul 31, 2009 | 03:41 PM
I.B. Washincars's Avatar
I.B. Washincars
With so few miles per year I can't ever see you justifying the extra 6K or so for a diesel. From what many here say, the V10 will almost pull with the diesel and you don't drive it enough miles for the fuel usage to be much of an issue either way. Go with the V10 gasser.
BTW, I have an '08 with a V8. I don't tow at all, but need to haul 2-3K in the bed every now and then. The truck handles it just fine.
Old Jul 31, 2009 | 03:45 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
You DO have to remember, the "extra" cost of the diesel will come back to you when you sell!!! If you plan to drive the truck 'in-between' tows, the better mileage of the diesel will also come back in profit! The V10, which you WILL need if you buy a NON-diesel, only gets 10-11 MPG NOT towing.
Old Jul 31, 2009 | 04:18 PM
bpounds's Avatar
bpounds
I would probably have said V-10 because you say you won't use the truck very much. Except that you drive a diesel now, and with that experience I'm gonna bet you won't be happy with a gas motor. Either motor will do the job. I just hate to see you kicking yourself later.
Old Jul 31, 2009 | 04:21 PM
Ace!'s Avatar
Ace!
Aren't the new diesels only getting slightly better than the V10 mileage-wise? If the rest of the truck is worn out how much more does the diesel get you in resale value after owning the truck for a period of time? Doesn't the diesel depreciate over time, and especially immediately after purchase, just like the rest of the truck does? I'm just trying to figure out if the mileage and extra cost will come back when sold. Is it only within a 10 year period of ownership, less, more?
Old Jul 31, 2009 | 04:22 PM
Deluxe05's Avatar
Deluxe05
Go with a V10 & 4.30 gears. When driving it, remember that the Ford Triton modular motors "like" their RPMs.
Yes, you can recoup some of that ~$6,000 "investment" in a diesel if you decide to sell/trade it, but you will likely never get it all back.
All anyone has to do is bounce between the V10 & 6.4L forums, and they will see that the 6.4L is not doing much better than the V10 in fuel economy. Having watched both for quite some time, I would say that the average reported fuel economy favors the V10 unloaded and the 6.4L in heavy towing/hauling.
Saying that the V10 will only get 10-11 MPG empty is not entirely accurate. I average 13's driving in Denver, and that is with my semi-heavy right foot and the heavy, 20" tire & rim option included with the Harley-Davidson package. And, no, it is not modified...100% bone stock.
Old Jul 31, 2009 | 04:26 PM
Ace!'s Avatar
Ace!
What's your location, and how tall is the pass? Will you be driving the pass each time you tow, or do you go to other locations? Do you have much experience with gas engines, or mostly diesel?
Bottom line, the gas engines will get you where you need to go, maybe slower, maybe faster, maybe in the slow lane and maybe not. You don't NEED a diesel to tow 12k lbs. The V10 truck has the same tow rating as the diesel and a higher payload, so if you need a little extra cushion payload-wise the gasser will give that to you and will provide the same towing capacity.
Old Jul 31, 2009 | 04:38 PM
Brojon2002's Avatar
Brojon2002
The hill is a slow speed pull do to the corners. I would say 35 mph or so. I think its about 7 miles long and 3,500 ft elevation difference. These are VERY rough numbers. My 7.3L non-turbo I have now has little power for the open road and is my first diesel truck. I have spent my time in the driver’s seat of many large pieces of equipment over the years so diesel and gas are both in the comfort zone.
Old Jul 31, 2009 | 05:39 PM
Fordfanatic4life's Avatar
Fordfanatic4life
V10...
the 6.4 would be wasted with so few miles/year...
Old Jul 31, 2009 | 05:41 PM
Carl Lassiter's Avatar
Carl Lassiter
A NEW truck, or new to you?
If NEW then move fast if you want gas as rumors are the V10 engine may be discontinued (I hope these are just RUMORS as it's the only big block gasser left among the pickup class)
The 6.4 engine seems largely fine but is new. 05 and onwards 6.0 was a good engine too. Can't go wrong with any of them unless you get unlucky. Most reliable new diesel is the duramax as it's had least dpf-related issues as it's been on the market nearly ten years improving each year. However, if you're a dyed in the wool ford guy that ain't gonna work
Old Jul 31, 2009 | 05:45 PM
Ace!'s Avatar
Ace!
Based on that "hill" and it's a 35mph sort of roadway it won't do you any good to be able to get up it any faster, so the diesel isn't a help. With that amount of miles I'd buy two trucks, with V10s, that way you don't have to put all those miles on one truck, you can have a commuter and a tower.
Old Jul 31, 2009 | 05:53 PM
Destroya's Avatar
Destroya
That is if it's still running at that point.
Old Jul 31, 2009 | 05:59 PM
dkf's Avatar
dkf
The V10 makes more HP and TQ than a non turbo 7.3l. The V10 with 4.30 gears will work well with plenty of power.
paiceman
6.7L Power Stroke Diesel
Feb 26, 2013 10:05 AM
mismith
Jul 19, 2012 11:13 PM
saggys
Escape & Escape Hybrid
Dec 22, 2010 10:43 PM
pilot4x41
Feb 9, 2007 07:52 PM
Jbsqared
Jan 26, 2005 11:53 AM
