Quick tach install question
Old Jul 31, 2009 | 02:51 PM
Ecks0117's Avatar
Ecks0117
After searching, I found that I needed to wire the tach to a dark green wire on negative side of coil... just wanted to know if this is the right one before I start splicing:
Thanks
Old Jul 31, 2009 | 05:45 PM
hydmech's Avatar
hydmech
looks like it could be the one. As long as it actually hooked to the tach. Make sure!
Old Jul 31, 2009 | 05:47 PM
uncle.stosh's Avatar
uncle.stosh
The coil only has two wires: A 12V positive and a negative and it's always green.
It may have 3 if you already have the pigtail for a tach - on older coils the negative has a Y connection already on it.
Old Aug 2, 2009 | 06:05 PM
Ecks0117's Avatar
Ecks0117
Okay, so I tested the tach and it works, so I just have 2 last questions:
I have a 302 and need to use both ground posts, is it okay to connect one post to the other then go to ground, or does each post need its own wire to ground?
Is it okay to wire the 12v post to the same switched power the radio uses, or is that not a good idea? I also planned on wiring a clock to that same wire.
Thanks
Old Aug 2, 2009 | 09:20 PM
6fifty_f1fifty's Avatar
6fifty_f1fifty
I have mine jumpered to each other and ground, the trons don't know the difference, a ground is a ground. Unless of course you are using something with high current, then you want a more stout ground.
jwhopson
19
Dec 9, 2012 10:58 PM
Ecks0117
15
Jul 27, 2009 08:49 PM
agryphon
Aerostar
Mar 5, 2007 04:47 PM
70blue
Georgia Chapter
Jan 31, 2006 08:45 PM
149113
1983 - 2012 Ranger & B-Series
Oct 20, 2005 08:30 PM
