Window Regulator question
Old Jul 31, 2009 | 09:42 AM
bulimic.cannibal's Avatar
bulimic.cannibal
Hi,
I'm replacing my window regulators with some from the junk yard and the shop manual says you should lube it up before putting it back in.
My question is what kind of lube should be used and what particular parts do I lube?
Thanks,
BC
Old Jul 31, 2009 | 03:19 PM
camperspecial65's Avatar
camperspecial65
I would recomend a white lithium type grease ...its a heavier grease then say regular wheel bearing grease...unless you get hipo light friction wheel bearing grease which is far superior and stand sup to heat well and make things move as slick as water across a smooth glass table...its not cheap though...but its top notch...
Lube up any contact parts or gearing parts...basicly whatever moves...dont lube the nylon roller between it and the pin it clips onto...just wipe whatever crud is on and in there and reassemble...also do use lube on the window lower sash though...where the roller slides into along bottom of the door glass...
- cs65
Old Jul 31, 2009 | 04:25 PM
bulimic.cannibal
Thanks! That's just the info I needed. I appreciate the help.
BC
jnoble87
Jan 23, 2015 07:37 PM
Pitcrw6
Oct 18, 2012 09:41 PM
RedHorse1
Aug 31, 2009 09:11 PM
Gage2502
Oil & Lubrication
Feb 25, 2008 04:02 PM
