Boost numbers
Old Jul 31, 2009 | 09:01 AM
fuzzy1626's Avatar
fuzzy1626
Boost numbers
Can someone tell me how much boost a 2007 6.0 should make in stock condition on the factory gauge?
Old Jul 31, 2009 | 09:30 AM
Cowboy65's Avatar
Cowboy65
I think around 30 psi is considered the max that should be run. My guage goes to 40 psi but I wouldn't run anything nearly that high. I'm considering a DashDAQ and will probably set the alarm at 28 or 29. Hopefully someone with more turbo knowledge will come by to confirm these numbers.
Old Jul 31, 2009 | 09:40 AM
bpounds's Avatar
bpounds
About 28 is the most I see. It might hit 30 lbs momentarily. Never seen it over the 30 hash mark. It redlines at 35 IIRC.
Old Jul 31, 2009 | 10:28 AM
KRDiesel's Avatar
KRDiesel
Depending on your flash 26 is "normal" it will peak higher but in a long pull 26-27 is correct.
