carbs...rebuild
Old Jul 31, 2009 | 01:58 AM
decscorpion's Avatar
decscorpion
Red face carbs...rebuild
got a 1977 F250 4WD Pickup built at the Mahwah plant in March 1977 and powered by a 8 cyl 400 cid 2-bbl engine.
i need to rebuild carb any1 got info how?<!-- / message --><!-- sig -->
Old Jul 31, 2009 | 02:11 AM
mark a.'s Avatar
mark a.
Get rebuild kit take it apart & clean it, put it back together. Nothing to it.
Old Jul 31, 2009 | 08:33 AM
superd02's Avatar
superd02
x2 there is really not secrets or tricky parts to rebuilding a ford 2 barrel
Old Jul 31, 2009 | 09:15 PM
montana_highboy's Avatar
montana_highboy
Buy the kit, rebuild it yourself, whatever you do DON'T buy a "remanufactured" carb, 9 out of 10 are completely worthless.
Old Jul 31, 2009 | 10:16 PM
oldmajor's Avatar
oldmajor
http://www.automedia.com/Motorcraft_...ht20020301cr/1
Old Aug 1, 2009 | 05:56 AM
66fdtrucknut's Avatar
66fdtrucknut
Should be a metal tag on it with no's. on it. Makes it alot easier to get the kit. Just pay attention to what your doing, comparing parts you take out and put back in. The kits come with extra parts that fit different carbs. Mainly gaskets. I just did this too. Good luck.
Charlie
Old Aug 1, 2009 | 07:08 AM
montana_highboy
When it comes to carb rebuilding cleanliness is next to godliness, if you don't have a tub of Berrymans B-12 at least buy a spray can of Berrymans and thoroughly clean your parts, an air compressor to blow out the passages would be a huge plus too, then just reassemble, it's really not that hard.
Old Aug 1, 2009 | 01:41 PM
SeattleWills's Avatar
SeattleWills
Make a area to to do it. I put down a few lint free rags. Get every thing out laid out nice and neat. Get some directions and Carb kit, I used carb cleaner, pipe cleanesr and a dremel to clean mine. Lay things out in the order you take them apart and reverse that when you put it back together. It is really easy, I also used some light machine oil to lube screws and my gaskets so nothing was going back together dry.
I would say #1 thing dont over tighten small screws or you could break them off.
That is my advice.
moosey1981
1983 - 2012 Ranger & B-Series
Jan 21, 2015 11:58 AM
gangstakr
Jul 25, 2014 07:35 PM
Mike_Torello
Dec 23, 2010 08:45 PM
GeoDaddy
New Member Introductions
Feb 4, 2006 06:34 PM
Phinxter
New Jersey Chapter
17
Oct 6, 2005 08:51 PM
