Hey all, I'm putting cross over steering (inverted T ala 90 F-350) on my 76 crew cab, 4x4, using a saginaw box off of my 2wd 97 Dodge engine donor. Question is, what application used a pitman arm the same length but tapered for a ball joint instead of having one pressed in? Pitman arm can be flat.
Another option is to find something similar to adapt the drag link to the ball joint thats in the pitman arm, but sky doesnt make em for Ford or Dodge. Thanks a bunch for any input.
