Sponsored by: Kumho
Power brake question ............
Old Jul 22, 2009 | 12:39 PM
eshaver's Avatar
eshaver
Hey gang, before ya'all go off on me bout what power brake thiscar came from let me remind you I ownboth a 53 Ford Panel Delivery and a 78 F-100 Stepside .
Anyway the wife bought a ragged out 1987 Mustang L X . It has the power disc's . The pedal travel is exessive even though I have adjusted the rear brakes and bled the system twice. I seem to remember some one somewhere on te forum tellingsomeone that you could adustthe pedal travel from under the dash , that right ? Ya'all can e- mail me at edshaver @ ymail . Ed Shaver
Old Jul 29, 2009 | 06:11 PM
frankyford's Avatar
frankyford
I've never heard of being able to adjust the brake pedal travel in a mustang or any other vehicle. Have you checked to see if the back brakes were wet with brake fluid, are you sure your master cylinder is operating correctly. Is there any fluid loss when it sits for a while, are you sure you bled them properly and thoroughly. Just some ideas to throw at you.
Old Jul 31, 2009 | 10:49 AM
DROPTOP46's Avatar
DROPTOP46
Check with No Limit Engineering, they make a "ratio adapter" that bolts on and changes your pedal ratio. it is not in their catalog, it comes in the P/B kits that they make, but they will sel it seporate if you call them.
John Morton
Nov 28, 2013 07:50 PM
SDATTI2D
New Member Introductions
Dec 25, 2005 04:17 PM
Carlene
Mar 7, 2003 07:31 PM
