Oil & Lubrication
5W20 oil analysis
Old Aug 3, 2002 | 01:20 PM
hitecdan's Avatar
hitecdan
5W20 oil analysis
FYI
Understanding the Blackstone Laboratories' Oil Report for gasoline and diesel fuel engines
Averages: The universal averages column is the average of all the samples we have analyzed for the particular equipment make and model. The unit/location averages column is your average wear for that particular type of equipment. They are both running averages and change with the number of samples we analyze.
Elements:
Elements are quantified in the- oil at parts per million levels (PPM):--This list shows the most common sources of the elements in a gasoline or diesel engine oil.
Aluminum: Pistons, bearings, cases (heads & blocks).
Chromium: Rings, a trace element in steel.
Iron: Cylinders, rotating shafts, the valve train, and any steel part sharing the oil.
Copper: Brass or bronze parts, copper bushings, bearings, oil coolers, also an
additive in some gasoline engine oils.
Lead: Bearings.
Tin: Bearings, bronze parts, piston coatings.
Molybdenum: Anti-wear additive, some types of rings.
Nickel: Trace element in steel.
Manganese: Trace element, additive in gasoline.
Silver: Trace element.
Titanium: Trace element.
Vanadium: Trace element.
Boron: Detergent/dispersant additive, anti-freeze inhibitors.
Silicon: Airborne dirt, sealers, gaskets, anti-freeze inhibitors.
Sodium: .Anti-freeze inhibitor, additive in some gasoline engine oils.
Calcium: Detergent/dispersant additive.
Magnesium: Detergent/dispersant additive.
Phosphorus: Anti-wear additive.
Zinc: Anti-wear additive.
Barium: Detergent/dispersant additive.
Physical properties:
Viscosity, flashpoint, % fuel and anti-freeze, % water and insolubles are all measured in gasoline and diesel engine oils. If fuel is present in an oil, the viscosity and flashpoint will often be lower than what was stated in the "Values Should Be" line. lnsolubles are solid material that is centrifuged out of the oil. They are typically free carbon from the oxidation of the oil itself, along with blow-by past the rings.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
