HPOP Spring
Old Jul 30, 2009 | 04:00 PM
aczar's Avatar
aczar
HPOP Spring
Had an o-ring on the output line of my HPOP blow out and while trying to reinstall it the spring went bye-bye and I cant seem to find it. Does anyone know if you can get just a spring from somewhere. Ford says you have to buy the whole HPOP to get it.
Old Jul 30, 2009 | 04:05 PM
Hiflyer746's Avatar
Hiflyer746
Don't buy a whole HPOP for the spring. God ford dealerships really **** me off! I don't believe you actually need the spring. I believe its just for a check valve and I don't believe its necessary. Guy? agree? Otherwise contact some manufacturers of aftermarket pumps and lines(dieselsite stealth ect.) and see if they have anything. I'm sure somebody can get you one.
Timmy
Old Aug 12, 2010 | 06:38 PM
SBChero's Avatar
SBChero
i know this thread is over a year old, but i had the same issue, and after talking to Joey @ Terminator you do not need the check valves.
and per the diesel site install instructions for thier hpop, removing them balances the pressure between the rails and you no longer need a HPx.
im installing my terminator modded hpop tonight and am not going to run the check valves.
just thought id update this thread as i was looking for the same information.
