Column To Floor Shift
Old Aug 11, 2009 | 05:24 PM
  #46
LARIAT 85's Avatar
LARIAT 85
Originally Posted by uncle.stosh
What he has going on there looks like crap. There is no other way to put it and I'm sorry if anyone is offended. On second thought, no I'm not.
Stosh, you have a way with words. It looks like you are on a ROLL with your lousy attitude and your harsh words.
I can't believe you are still allowed to post on this forum at all, with all your disrespectful antics to the other members here.
That is a real cute signature you have under your name there.
Old Aug 11, 2009 | 08:47 PM
  #47
TheKirbyMan's Avatar
TheKirbyMan
F3Beam, how is this setup working for you on the road?
Old Aug 11, 2009 | 09:31 PM
  #48
F3Beam's Avatar
F3Beam
Hard pressed speedometer cable conked out after about 10mi. I loosened the bracket, installed speedo cable, and bolted bracket back...notice the hard strain on the cable around bracket in pic, I'll have to grind or drill a hole or something...I'll need to repair and fix this...as I roll along
Other than that, everything better. Clutch is much better than ever before...truck is running...and as was mentioned before, I am going to try and "Level" the linkages out a little tomorrow morning.
If you flip the linkage down, it will reverse the gear shifting pattern...upside down pattern...and require using the rod linkage extension...but there is still room for adjustment by using the top hole and a little change on the gear selector hole.
These custom floor shifters do seem to want to install to close to the seat. Not sure if seat will go back any farther...but will try...not perfect, but working...
Old Aug 11, 2009 | 09:35 PM
  #49
mds47588's Avatar
mds47588
Glad that you got your truck going again. I've been watching this thread for awhile now and can sympthasize with your frustrations.
Old Aug 11, 2009 | 10:16 PM
  #50
first today's Avatar
first today
If you undo the bolt on the shifter under the truck, it can be re mounted further up the bracket. It looks like you could go forward two holes.
Old Aug 11, 2009 | 11:47 PM
  #51
4caster's Avatar
4caster
Thanks for your thread on converting a column shift to stick! I'm sure that it will be encouraging to others in the future.
Old Aug 12, 2009 | 07:50 AM
  #52
F3Beam's Avatar
F3Beam
Not quite as easy as it looks...that little bracket with the bolt holding the shifter pivoting point is hard attached to that hole. Welded I think...that shifter bracket and the rest of the support bracket is like one solid piece. You'd have to chop it off, move to next hole, and re-weld to shorten...or that's how it looked to me.
Now, the Mr. Gasket #7667A has two bolts where that can be adjusted. Hurst is probably a good bit stronger because of how it is made, but not as easily adjusted...Hurst pivoting point pressure looks solidly centered...Mr. Gasket looks more offside to center...I think maybe that is so...
You can't help but notice how close it is to the seat as is, but it has not hindered or bothered anything at all so far...in fact, I may like the tucked back out of the way placement after awhile.
The front gear selector bracket has side-to-side wobble, a little shim washer should take the wobble out this morning...but the speedometer cable looks to be the biggie for me now. There is no 90 degree offset device as mentioned before, is there? I need to give it some thought as grinding is not that appealing, but there may not be a better option...
Old Aug 12, 2009 | 08:32 AM
  #53
F3Beam's Avatar
F3Beam
You know first, I think you are 100% right. My mind was blinded by the thought it was welded on, but right now as I look with flashlight...there looks to be one bolt holding it in place other than the pivot bolt. It does indeed look adjustable. I change my mind...ha.
Old Aug 12, 2009 | 12:54 PM
  #54
first today
When the speedo gear is off of the cable, is the cable diameter small enough to get away with drilling a hole in the side of the bracket? Then you could pass the cable through the bracket and re attach your speedo gear. That would not take any strength out of the bracket, and would take stress off of your cable.
Old Aug 12, 2009 | 01:12 PM
  #55
F3Beam's Avatar
F3Beam
In fact first today, I did go unbuckle the shifter handle, linkages, pivot (Center) bolt, and the one bolt holding the shift bracket to move it forward one hole. Thanks for pointing that out again. Had to cut the hole in floorboard another inch forward but now have plenty of room to shift...and, it is now shifting excellent. No trouble getting into any gear at all now.
Just remember to adjust distance to your liking before cutting hole...I had a small hole cut and boot still covered the adjustment after extending...just lucky.
I tried moving the linkages around to different holes, but for one reason or another I went back to the original position in picture above...worked best for me.
Easy to follow Instructions:
Not that clear of a picture...but:
Gear selector towards front of transmission (On left): Forward position is 3rd gear, middle position is Neutral, and back position is 2nd gear.
Gear selector towards rear of transmission (On right): Forward position is 1st, middle position is Neutral, and back position is Reverse.
Gear selectors in pictures are in Neutral.
Old Aug 12, 2009 | 01:18 PM
  #56
first today
Do you see the difference in quality between the two shifters? Unless the Mr. gasket has changed, the big difference is the spring loaded shifter on the hurst. It is really smooth and does not need to be forced. It does take getting a little used to.
Old Aug 12, 2009 | 01:25 PM
  #57
F3Beam's Avatar
F3Beam
You know, maybe that will work. I didn't pull the speedo gear off to see how big the cable was without it...but it just might work! This is the only problem I see that I have left regarding the column to floor shift conversion and will tackle it in a few days after a rest stop. I'm not sure if I can just replace the inside cable part with a kit or will need the housing too...bracket might have gouged into the housing...but no matter, I'll look into it soon enough.
Wow! Can't believe how great truck is shifting now. Good luck to anyone that has to do this. And be careful too!
Old Aug 12, 2009 | 01:43 PM
  #58
F3Beam's Avatar
F3Beam
Yesterday, I was forcing it a little...trying to control it too much...today, just glide it forward and it finds second gear by itself. Does take getting a little used to. And besides, yesterday shifting got bad but when I got home I saw the nut on a gear selector had backed off. Lock washer was missing. I put a lock washer on it, tightened it up good, and today it is shifting great.
The Mr. Gasket looks nice, clean, and shiny. But I have no idea how it works. I'd have to connect it to the transmission and see how the spring loaded pin snapped into place when shifting. I'd just as soon stick with the Hurst Indy as long as it is shifting like it is now. It probably is quite a bit better...but I've never tried a Mr. Gasket #7667A, even though I bought one.
Old Aug 12, 2009 | 02:02 PM
  #59
first today
That is good to hear and glad to see your back on the road.
I have used both shifters and am a big fan of the hurst. Good luck with the rest of your truck.
Old Aug 12, 2009 | 07:33 PM
  #60
FordNFishinLover's Avatar
FordNFishinLover
F3beam, awesome work man!!! Im very glad to hear that you are back on the road and your truck is running better than ever!!
It seems like this was quite a project but you came through and got past your problems with it!! Hope it continues to run forever!!!
