Oil pressure sending unit
Old Jul 29, 2009 | 04:52 PM
chaser1602's Avatar
chaser1602
I installed an oil press gauge were the original idiot light sending unit was installed.I still want to keep the idiot light,so I need to find another port.Is there another one on a 352?
Old Jul 29, 2009 | 07:28 PM
daveengelson's Avatar
daveengelson
Seen an adapter, just don't recall seeing one for both sensors, perhaps more knowledgable member would know. I used regular threaded pipe about a 3", believe it's 1/4" and threaded one end into the block, then installed a small 't' fitting with the 't' leg facing up. Since the electric sensor is larger, installed it at the end of the 't' and the other sending unit screwed into the leg facing up. It does not interfer with changing the oil filter, and the total length puts it around level with the oil filter. Originally went with brass pipe for asthetics but found it tends to crack due to engine vibration; however, the 't' fitting is brass. Installed few years back with no problem.
Old Jul 29, 2009 | 08:55 PM
chaser1602's Avatar
chaser1602
Putting a T in would be plan B for me.Not a whole lot of room with the P/S pump there.I looked behind the intake but didnt see one there.Maybe need to look harder.
Old Jul 29, 2009 | 10:39 PM
camperspecial65's Avatar
camperspecial65
Originally on the trucks with the extra gauges there was an adapter that screwed into the engine which has 2 outlets..one for the small idiot light sending unit which the flat slip on wire goes onto. The other style used a can for the electric gauge...the threads are the same as the threads on both of the sending units.
- cs65
Old Jul 30, 2009 | 12:19 AM
daveengelson
Also have the power steering pump, as well as headers, actually can't see the set up or would have taken pic's. Having said that, it's what ever works best for u.
Old Jul 30, 2009 | 07:24 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
One for the small idiot light sending unit which the flat slip on wire goes onto. The other style used a can Can? for the electric gauge.
The threads are the same as the threads on both of the sending units.
C5TZ9B339B .. Adapter (Fitting) Oil Sending Units / Obsolete
ANTIQUE AUTO SUPPLY in Arlington TX has ONE = 817-275-2381.
JST AUTOMOTIVE in Lebanon TN has ONE = 615-443-3086.
B & L FORD in Ashland PA has TWO = 570-875-4417.
GREEN SALES CO. in Cincinnati OH has 13 = 800-543-4959.
The oil pressure sending unit used with the oil pressure gauge is dome shaped.
The same sending unit fits: 1957/96 cars/trucks.
E4ZZ9278A .. Oil Pressure Sending Unit / Use with Oil Pressure Gauge (Motorcraft SW1547B)
E4ZZ9278A replaced: D9ZZ9278A, C9ZZ9278A, C7ZZ9278A and B7T9278A.
The oil sending unit used with the warning (idiot) light fits 1956/96 cars/trucks.
D4AZ9278A .. Oil Sending Unit / Used with Warning Light (Motorcraft SW1311A)
D4AZ9278A replaced: C8AZ9278A and B6AZ9278B.
Old Jul 30, 2009 | 08:35 PM
chaser1602's Avatar
chaser1602
Thanks for those #'s NumberDummy.My fingers are itchin' for the morning
jschluter
Jul 20, 2015 08:23 AM
ihcc104
35
Feb 27, 2015 05:24 PM
bert cook
Nov 10, 2014 02:49 PM
fordboy97
Nov 6, 2014 10:07 PM
ChristopherN
24
Aug 13, 2011 09:32 PM
