What Size Tires? Lift?
#31
#32
You will need an arm that fits your box. Chances are that you may find a box from a salvage yard and those chances are pretty good that the box will have an arm on it already. Most folks dont take pitman arm pullers to the salvage yard. This means that most boxes will have an arm still attached.
Search for power steering upgrades, and you will find many early truck owners that have made this upgrade. Some have gone all the way and upgraded to crossover, some went the inverted "T" route and others have used the stock configuration. Each works for individual applications but all share the same amount of fabrication.
I fabricate and things come fairly easy to me. Unfortunately what comes easy to me may be a chore for others.
In order to upgrade to this box one will have to be able to weld at a minimum.
#33
The majority seems to agree that most driveshafts are safe up to 6 inches of lift, so the small lift that you are looking for will be fine.
Please take the above advice and consider another method of lift for the front. Blocks can be dangerous up front and are not very popular.
i eat hybrids
07-24-2021 09:27 PM
HuskyFlareside
01-05-2016 09:59 PM
