Sponsored by: Real Truck
Fuel injector problem
Old Jul 29, 2009 | 07:16 AM
2k84's Avatar
2k84
Hello, I am new on here. I have a 2001 F250 5.4 with 85000 miles. The problem I have is it started missing the other day. Took to my mech. and he said #5 cyl. misfire. So he change all plugs and coil on #5. That didn't help. Then he ran some more test and said the injector was not working. He switched out between cyl. and found that #5 injector wire was not getting any juice. He said I needed new ecm. So yesterday I had the ecm replaced. Still does not work. Does/has anyone else have this problem?
Thanks 2k84
Old Jul 29, 2009 | 06:19 PM
FireMe's Avatar
FireMe
The injector circuits are very simple. One pin at the injector connector gets supplied with battery voltage from the PCM relay whenever the key is in the "ON" position. The other pin gets grounded by the PCM to turn the injector on.
Since all the injectors are fed from the PCM relay, you either have an open circuit from the point that the wire harness splits to feed each injector, or you have an open circuit from the injector to the PCM.
These checks should have been done long before any parts were replaced, and it takes literally less than a minute to check the injector circuits at the injector connector. After that, a few more minutes with a DVOM will find the problem.
Old Jul 29, 2009 | 06:29 PM
Mustang6147's Avatar
Mustang6147
I was thinking the same thing when reading his post. Well said, I couldnt agree more.
Old Jul 29, 2009 | 06:49 PM
ReAX's Avatar
ReAX
Did the diagnostic software show a bad injector/injector wiring?
A simple test just to verify, the switched wire (orange I think) will show AC voltage if it's working. The strobing of the ground will read kind of like AC voltage and a DMM should show ~5vac at idle and more voltage as the RPMs increase.
Old Jul 29, 2009 | 09:28 PM
2k84's Avatar
2k84
Thanks guys. They found the problem. it was the ground from the injector to the pcm. He ran a new wire and its back to running great. Thank you for all your help.
kennyr
Jul 9, 2011 11:25 PM
mommie5324
Feb 14, 2010 10:01 PM
Truxx1956
2004 - 2008 F150
Dec 30, 2009 09:36 PM
short76
29
Mar 24, 2009 02:11 PM
