d44????
Old Jul 28, 2009 | 10:06 PM
pro70golfer14's Avatar
pro70golfer14
d44????
About a year ago i busted the D44 chunk in trhe IFS in my 93 f-150. I only busted the spider gears and the ring and pinion is fine. I ended up just putting a new chunk in it because my buddy had one laying around. So the busted chunk went to laying in my back yard. Well recently i busted the ring and pinino in the D44 straight axle in my 79 f-150 (mud truck). Question being will the good ring and pinion out of my 93 go in the D44 in the 79.
Old Jul 29, 2009 | 12:21 AM
bmf316's Avatar
bmf316
i would think a D44 is a D44, pull the ring and pinions and compare them, also are they the same ratio?
Old Jul 29, 2009 | 08:01 AM
pro70golfer14
yep 3.55:1 gear ratio
Old Jul 29, 2009 | 10:28 AM
alxsnmr's Avatar
alxsnmr
Checking against the broncograveyard listing, Yukon gear and axle listes the same catalog number for the 3.54 gear ratio in the 78-79 dana 44 reverse cut and the 1980-1996 dana 44 reverse cut ring and pinion gears. So take it for what its worth.
Old Jul 29, 2009 | 11:28 AM
Diesel_Brad's Avatar
Diesel_Brad
you want to use a ring and pinion that has been laying outside for a year?
Old Jul 29, 2009 | 10:54 PM
pro70golfer14
dont really care it is a mud truck and it is the front end which dont get used that much in this truck believe me
