i have a 79 f100 and im looking to install a late 80's early 90's f150 tranny 5 speed. will i need to change to hyd system? and the peddle assy? thanks
I modified an '86 hydraulic style bellhousing to accept the old style mechanical pivot bracket thereby negating the need to go to a hydro clutch. Basicaly just had to "shave" off the "ears" that mounted the slave cylinder to the same thickness as the stock mounting holes. Or you could just use an old style bellhouding I think
Although they use all new aftermarket parts I wouldn't think converting the OEM parts would be much different, if you haven't already done so grab as much of the donor truck's hardware that you can.
