Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Tire Problem
Old Jul 28, 2009 | 06:10 PM
FordHubby's Avatar
FordHubby
Tire Problem
I have an 03 Escape w/3.0, 127k+ miles. I'm on my 2nd set of Continental tires and I think I have a problem with the left rear wheel/axle. Each tire on that wheel has developed uneven wear. It's very noisy and rough. I just had the alignment ck'd and was told everything ck'd out fine- no adjustments required. Has anyone else had this problem? Does anyone have a suggestion?
Old Jul 28, 2009 | 09:36 PM
tcesni's Avatar
tcesni
I wonder if you might have a weak strut that is impacting tire wear.
Old Jul 28, 2009 | 09:49 PM
GLoiselle's Avatar
GLoiselle
If you are going over 5k between rotations and not keeping air pressures up,may be cause if not get rear suspension upgraded.With that mileage get new rear shocks, and have rear sway bar link pin bushings upgraded to polyurethane.
Old Jul 30, 2009 | 09:24 AM
FordHubby's Avatar
FordHubby
Thanks for the suggestions. I admit I rarely rotate they tires-- I never think about it.
Old Jul 30, 2009 | 12:53 PM
Jonas1022's Avatar
Jonas1022
Exactly, these trucks are sensitive. Doing the 5K rotate and balance thing is crucial to even tire wear. Contitracs seem to be the worst about the wear and noise thing. Firestone on the other hand seems to have a tire that works better than any tire that Ford puts on these trucks.
Old Aug 2, 2009 | 11:33 PM
sfcwoodret's Avatar
sfcwoodret
Get rid of the Continentals as soon as you can and you won't regret it.
Old Aug 6, 2009 | 07:21 PM
mudguy33's Avatar
mudguy33
dosent matter what tire you use , the wear is going to be the same on a $50 tire or a $200 tire there is an allinement problem with all of them get used to it.
Old Aug 6, 2009 | 09:01 PM
tcesni's Avatar
tcesni
I have 160,000 miles on my '02 and 22,000 miles on my '09 and have never had an alignment problem.
Old Aug 6, 2009 | 09:13 PM
Mustang6147's Avatar
Mustang6147
DO the tire rotation at the same time as oil change... This habit will help you remember
Old Aug 15, 2009 | 02:31 PM
aquanaut20's Avatar
aquanaut20
Thank you, now I know I am not the only one, my wife thinks I am **** about tire rotation...
Don't have to worry about balance, installed beads inside tires 3 yrs ago. Has increased tire life 20%, re-balances every time I stop.
Old Dec 23, 2010 | 11:11 AM
jechternach's Avatar
jechternach
Same tire wear problems
I get inside tire wear (04 tribute) with second set of continentals. My mechanic has suggessted new struts but I don't know about this as a fix. I replaced the rear shocks and continued to see the wear on the back even after an alignment. Many people have this problem with the contitrac tires. Just look around when you see escapes and tributes (I have been looking around and in the last week I have seen 5 escapes and tributes with the conti's with the same wear issues as me) If you ask me there is a problem. I have owned many cars and suv's and never had issues like this.
I will soon replace tires with quality michelins and go to a specialty alignment shop to see if there is a problem. Some suggest camber kits as a fix as well. Other forums I have read lead me in the direction that there is a problem with the oe tires, the suspension or both. Others on this forum solved the wear and horrible noise issues with michelin tires. I rotate at every other oil change (6000 miles).
Check out these links to read about this problem
http://www.topix.com/forum/autos/T5UB6MFBE58IJ38E1
http://mazdaforum.com/forum/showthread.php?t=20619
http://www.topix.com/forum/autos/for...2FDOFIHJJU8/p5
Old Dec 23, 2010 | 05:05 PM
scottss80's Avatar
scottss80
Jechternach,
Just FYI on the tires I've had on for about the last 56,000 miles with zero problems are the Michelin LTX M/S 2. There is also an all terrain version of this tire Michelin LTX A/T 2, but any all terrain tire is going to be more noisy with the way tread wear is designed. The difference with my old tires and the Michelin LTX M/S 2 (Discount tires) was night and day, and with 145,000 miles I have had no suspension problems except replacing the sway bar links, and zero uneven wear on these tires.
Happy Holidays, Merry Christmas!
Scott
Old Dec 28, 2010 | 08:45 PM
FordHubby's Avatar
FordHubby
Update
I finally had my dealer check the alignment and it was in fact out of alignment.
Next time I buy tires I doubt I get Conti's. ALthough I did get nearly 80k on the original tires. But the Conti's are noisy.
Thanks for all of your replies!
Old Dec 28, 2010 | 09:38 PM
tonyford's Avatar
tonyford
That is quite rare that the rear axle went out of alignment, but anything is possible. I would like to hear how this goes and if you have any more problems with that same wheel.
I am thinking that the wheel itself got damaged somehow and was terribly out of balance. That would also cause the same problem you had. But Ford says it was the alignment, so be it.
Old Mar 13, 2011 | 09:35 PM
FordHubby's Avatar
FordHubby
Updat on tire probs
I finally broke down and bought 2 new 65k mile Yokohoma's last week. It is unbelievable what a difference it made. I kept 2 Conti's that still have good tread(moved them to the back). The ride AND road noise is soooo much better. It's like a new car. I got a lot of miles, almost 80k, from the Conti's but I'll never buy another one: too much noise
