glow plug relay test
Old Jul 28, 2009 | 12:03 PM
jad4's Avatar
jad4
I was wondering how exactly this is done. key on? when I put the screwdriver on the terminals do I then run around and try to start or do I need a helper.
Old Jul 28, 2009 | 12:29 PM
superduty4x4's Avatar
superduty4x4
It helps to have someone inside to run the key for you.
Key off- put your multimeter black probe on a good ground and the red probe on the large post of the GPR closest to the fender. Should have around +12V. Now put the red lead on the other large post, should be 0V.
Key on (but not cranking)- both large posts should have +12V. If there is more than 1V drop across the relay it's time for a new one.
Old Jul 29, 2009 | 09:45 PM
IDMooseMan's Avatar
IDMooseMan
Thanks for the instructions, Chase. Reps sent.
Old Jul 30, 2009 | 12:12 PM
cowmilker08's Avatar
cowmilker08
What if you want to check if the gpr is stuck on?
Old Jul 31, 2009 | 12:12 AM
IDMooseMan's Avatar
IDMooseMan
Not sure what you mean, Phil, but when my GPR was going out, I could hear it "clicking" on and off with the engine running. Is that what you mean by "stuck on" or are you referring to something else?
Old Jul 31, 2009 | 12:35 AM
Eric_F250's Avatar
Eric_F250
if stuck on, i think it stays super hot (temp) and your voltage gauge never comes up. then your batteries die a painful death because alt can keep up with draw. or at least i think that is what happened with me
