Expy front shocks
Old Jul 28, 2009 | 06:40 AM
joe shmoe's Avatar
joe shmoe
Expy front shocks
Curios as to how I could find out if my front air shocks need replacing,got a 01 Expy w/4 wheel air suspension,truck has been a little loose in the front .had tires rotated and balanced,but still seems loose.any suggestions?
Old Jul 28, 2009 | 09:11 AM
Omahastro1's Avatar
Omahastro1
How many miles
Old Jul 28, 2009 | 04:15 PM
bnovak's Avatar
bnovak
Take a measurement of the front end when you first park it, then measure it the following morning at the same spot.
If it's different, your front shocks need to be replaced.
Depends what you consider "loose"
to me, that sounds more like a ball joint or Tie Rod end issue.
Old Jul 28, 2009 | 04:32 PM
Omahastro1's Avatar
Omahastro1
My Expy would get loose at times on certain surfaces of concrete and I replaced both the front and back. I could be wrong sure wouldn"t be the first time, but I think the front shocks are two different actions. One is the lift from the air portion and one is the shock portion. I replaced front and rear around 50,000 miles and what a difference it made.
Old Jul 29, 2009 | 06:20 AM
joe shmoe's Avatar
joe shmoe
Its got 74k miles on it.Its seams loose or like the tire is bouncing on the hwy,not slow speeds,that's why I thought it was the wheel balance.I'll try the measurement thing.Thanx
Old Aug 7, 2009 | 09:32 PM
Gevans17's Avatar
Gevans17
I'd say after 74,000 miles, you are past ready for a new set of shocks.
