Help with my codes please
Old Jul 28, 2009 | 12:12 AM
JasWood's Avatar
JasWood
I have a 99 Expi. with 139k on it with the 5.4. It's been bucking and stalling on my wife. I ran the codes and they read: P0401 P1299 P0300 P0443 P1451 P1309 I took it to the dealership last year for similar issues and they stated it could be the #4 coil back feeding into the PCM or a bad computer. I took it home and replace all of the coils with Accel super coils, and have since replaced the coils on three different cylinders. The temp gauge reads fine. I need to fix this because it stalled in an intersection today with my kids in the truck with her.
Old Jul 28, 2009 | 12:29 AM
alloro's Avatar
alloro
Have you connected a fuel pressure gauge to the fuel rail to determine if the fuel pump is weak?
Old Jul 28, 2009 | 12:37 AM
JasWood's Avatar
JasWood
I'll check again in the morning. Running was like 32 and off was like 40.
Old Jul 28, 2009 | 07:33 PM
JasWood's Avatar
JasWood
Checked it again and the numbers were the same
Old Jul 28, 2009 | 10:14 PM
alloro's Avatar
alloro
Your pressure is low. Fuel pressure should be up around 45 PSI at all times.
Old Jul 30, 2009 | 02:03 PM
luvmyexpy's Avatar
luvmyexpy
get a good used pcm, see what happens from there. i bet that is the issue, or a wire harness short.
