Sponsored by: Real Truck
4x4 engagement problem
Old Jul 27, 2009 | 10:22 PM
MarksV10's Avatar
MarksV10
I have a 2001 Ford F250 4x4. I Selected 4x4 high at full stop rear wheels were in sand, light came on but only rear wheels turned, felt vibration. Got home,tested at a complete stop in nutural I could here a switching noise. Tested on a gravel road but couldn't tell if front wheels were ingaged.
What is the best waay to test and what could be the possible problem.
Old Jul 27, 2009 | 11:30 PM
EXv10's Avatar
EXv10
Go back to the gravel road and put your foot on the brake and the gas and let 'er rip for about 10 feet, get out and look at your tracks. I have a gravel road with a steep hill on it nearby for testing mine. Then do a search in here for your vacuum hub part of it and you can read all night on it. Also you can have someone watch your front wheels on the test. Just turning the wheel and waiting for the wiggly feel of your u-joints isn't good enough because one could be locked up or hub friction can make an axle turn. Also they don't all engage at a total stop. I backed off a back hills road on a steep drop to turn around and couldn't go back or forward because it was up against a tree. I knew my manual hubs would work though so I was out of there in a minute.
Old Jul 28, 2009 | 09:19 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
You can not engage 4x4HI at a complete stop. The front hubs will not lock during the initial vacuum pulse unless you are moving.
If you are driving on gravel, while moving, turn the **** to 4HI and then lay on the gas, it should be obvious if you are in 4x4.
If you are not, try locking the hubs manually and see if you get 4x4. If you do, we need to diagnose the hubs
Old Jul 28, 2009 | 09:36 AM
Lubbockguy1979's Avatar
Lubbockguy1979
Not to hijack but if you put it in 4hi and the hvac system goes to defrost then you have a vacum leak.... How would you diagnose that issue. What would you do to eliminate the hubs from the vacum hoses? I assume the vaccum pump still operates because after I return the truck to 2wd the ac will again blow out the vents instead of the defrost.
Leonandlisa
6.7L Power Stroke Diesel
Feb 10, 2015 07:26 PM
zrt600guy
1983 - 2012 Ranger & B-Series
Feb 14, 2012 04:10 PM
Ford Fx4
1997 - 2003 F150
Jul 30, 2008 06:35 PM
Chrisjc21
Apr 3, 2007 08:59 PM
GMayer
1997 - 2003 F150
Jun 28, 2005 09:12 AM
