Front Axle Wrap or Hop under Load
I was at the beach a few weeks ago and pulled a fully loaded suburban through some really soft sand. The front end on my 05 was hopping up and down a few inches while pulling them. It was shaking the whole truck. We had to stay in the throttle a little to keep the momentum up.
Is there anything that can be done to help the axle wrap / hop problem. My truck has a 6" lift with 35s. Would Poly bushings help?
wow!! 5 psi , that seems low. i beach camp in loose sand towing a 9000lbs trailer and i keep the air at about 17lbs. (truck and trailer)do you have bead locks?
Air down on sand as much as possible. I too run super low pressures (no beadlocks).
A locker will not help wheel hop. Dampers can help, but airing down will help. I pull a very large toy hauler and run pressures down to 8 sometimes 6 psi. Keeps the hops to a minimum and permits the truck to get some traction is heavy sand.
Used to run down to 5 psi, not pulling a trailer, on the sand dunes. Never had a tire come off and no bead locks. The wheel hop seems to me, in soft sand, that one tire will dig in finding traction then switch power to the loose side. Airing down and a locker would prevent the switching back and forth but I am no expert on sand.
octaneforce
28
11-19-2017 02:09 AM
OldBlack4x4
04-28-2015 05:18 PM
Jason302
08-23-2011 08:01 PM
