Trailer lights problem
Old Jul 27, 2009 | 05:22 PM
shov76's Avatar
shov76
Having a problem with the trailer lights lately. HD tow package but no runnig/park lights. No juice to the pin marked running lights. Any idea of how it runs back?. Is this part of the 2 splice blocks I see under the truck/left frame rail under drivers seat?. Any schematics or help on this one? Have juice to the fuse and relay. Sshould it click when the key is on or could there be a short?. I know....lots of questions but the feedback would be appreicated.
Thanks in advance,
Shov
Old Jul 27, 2009 | 06:42 PM
GaryJr's Avatar
GaryJr
Just out of spite have you changed the fuses! you will have one for turning each side and one for the running, I have had a fuse before that looked good but changed it and lights worked! put the fuse to a ohm meter and yes it was bad just looked good! Good luck!
Old Jul 27, 2009 | 09:30 PM
alloro's Avatar
alloro
Should it click when the key is on
Yes the 2 splice block could be the problem, it was on my expedition. I had to repair two wires there that were corroded.
Any relay for the parking/running lights should click when the parking lights are turned on. Since these light work whether the key is on or off, any relay clicking will follow the light switch and not the ignition key switch.
Old Jul 28, 2009 | 09:30 PM
shov76's Avatar
shov76
On the money Garyjr.. forgot to CHECK THE FUSE!!!!!! All set now thanks for the feedback. Always think the worse and forget about the easy fix first. That old gag!!!!!!!!!
shov76
Jul 20, 2015 07:51 AM
DeanBob
May 15, 2012 09:14 PM
danlyst13
Electrical Systems/Wiring
Apr 8, 2008 12:16 AM
shov76
Jan 29, 2008 08:27 PM
shov76
Dec 12, 2006 07:49 AM
