I bought a 88 f150 300I6 with a dand44 front end and 8,8 rear, 5 speed manual truck for $500.. and everything bolted up beautifully the only thing i had to do was get a drive shaft made because the donor truck was a longbox..
I sold the engine for $300 the Box for $200 and the Chassis wiring for another $100 And i got my Drivetrain that i wanted..
i highly suggest buying a donor.. eventually you will want the heavyer duity rear leaf springs, (means you have to use the leif brackets off of the 4X4,, grinding and bolting them on) and you will want the odds and ends that you wont have from the junkyard..
