Oil & Lubrication
tropartic
Old Oct 28, 2002 | 05:02 PM
rgiles's Avatar
rgiles
tropartic
Old Oct 29, 2002 | 10:53 PM
86bronco2jeff's Avatar
86bronco2jeff
tropartic
I use tropartic what do you all think of it and does anyone have any specs on it is it good oil?
Old Oct 29, 2002 | 11:28 PM
BrianA's Avatar
BrianA
tropartic
Typical Properties: Values are representitive of current production SAE Number Grade ------------ 10W-30
Stock Number 42970
Specific Gravity .8670
Flash Point COC, C (F) 226 (439)
Pour Point, C (F) -37 (-36)
cP @ -25C 6086
cSt @ 40 C (104 F) 79.0
cSt @ 100 C (212 F) 10.71
Viscosity Index 148
Sulfated Ash, % 0.8
the numbers above are from the Philips 66 web site (search on "Tropartic" and you'll find it.
I'd guess it would be fine motor oil.
Brian A
Old Oct 30, 2002 | 03:39 AM
Torque1st's Avatar
Torque1st
Posting Legend
tropartic
Trop-Artic is great oil. I have used it since ~1968 b4 it got hard to find and I switched to Valvoline about 2 years ago. TA keeps an engine extremely clean inside unlike many other oils. I have seen an engine back in about 71 with 100K+ on it that was run with TA since day one. It was an oil field rig that had the oil changed every two months. It was almost clean enough to eat off of... Not really but WOW! No carbon or varnish. The engine looked like it had just been assembled. Every vehicle that I have used it on since has been the same, -clean as a whistle.
Thanks for using FTE!
[font color=red]As a Moderator I do not "Subscribe" to most topics,
please send email/pm if you need a reply -Thanks![/font]
