put a 87 ford aod in my 68 and put a new b&m 2400 stall and did not hook up aod linkage but car wont shift pass 2 please help dont no much bout aods
You probably need a new direct clutch. Without the linkage the trans runs at minimum pressure. The direct clutch might be able to survive one shift at minimum pressure, but not two. It is almost certainly toast.
