Hoppin'
Old Jul 26, 2009 | 03:03 PM
stillneedswork's Avatar
stillneedswork
Hoppin'
hey, i have a 1996 f350 crew cab 4x4. when i slow down on the high way to get off it, the rear end of the truck bounces, it also does this when i am towing a boat, only it happens when i am accelerating or coasting, the shocks are good and the brakes shoes are fine. Anyone have an idea?
Old Jul 26, 2009 | 03:22 PM
broncoderek's Avatar
broncoderek
Can you describe it better? I picture wheel hop like when one tries to do a burnout but I'm gussing it's not that violent and more of something you feel rather than something you might see if you were watching from another vehicle.
Old Jul 26, 2009 | 03:34 PM
1966Tbird's Avatar
1966Tbird
warped brakes?
Old Jul 26, 2009 | 03:55 PM
ryanfrompoco's Avatar
ryanfrompoco
does it only do it a certain speed?
Old Jul 26, 2009 | 04:19 PM
DIYiT's Avatar
DIYiT
Check the U-joints. My truck did the same thing on acceleration (never noticed it during coasting...) and it turned out to be a VERY worn U-joint.
Old Jul 26, 2009 | 04:31 PM
jr32560's Avatar
jr32560
mine started doing that after I rotated my tires-the rear/front they were chopped pretty bad
Old Jul 26, 2009 | 06:39 PM
Neptoess's Avatar
Neptoess
my ranger did it from warped rotors
Old Jul 26, 2009 | 07:41 PM
stillneedswork
its definitly coming from the rear end, idk can drums warp? it feels like someone is jumping on the bumper, and it usually happens at speeds above 35 MPH. My U-joints are good i checked them recently
Old Jul 26, 2009 | 08:13 PM
Neptoess's Avatar
Neptoess
the shoes in the drums could be warped
Old Jul 26, 2009 | 08:18 PM
stillneedswork
i dont know, i looked at the shoes today and they still had plenty of meat on them, i would think that if they are going to warp it would be near the end of their lives
Old Jul 26, 2009 | 08:22 PM
nat13_3's Avatar
nat13_3
I had a similar problem from what I thought were good U-joints. Then all of a sudden one day it was toast. Replaced it and haven't had the bad vibrations since.
Now that I think about it mix 'n match is right the U-joint is more of a vibration than a hop. Sounds like axle wrap to me. If the leafs are old and warn they wouldn't be as strong anymore and would cause said symptoms. But if that were the problem, you'd probably be noticing it when you start off more so than at highway speeds. I get a bit of axle wrap when I let of the gas at any speeds but if you have an auto you shouldn't notice it as much. And if I hit the gas at any speeds I will get some.
And to play with his sig also... i didn't think before I lift and now I suffer from horrendous axle wrap but it is cool cause it makes it accelerate like a loaded semi...
Old Jul 26, 2009 | 09:00 PM
93 mix 'n match's Avatar
93 mix 'n match
does it seem to be 1 hop fer wheel revolution? i think if it were u-joints it would be faster then wheel revolution.....
Old Jul 26, 2009 | 10:31 PM
stillneedswork
i would say it is less than one per revolution, i had thought it may be axle wrap, but i dismissed it cause i hoped that it wasn't. if it is because of weakening springs, could i do anything about it other than replacing the springs? would it be best to drive it for awhile and see if it gets worse before i do anything drastic?
Old Jul 26, 2009 | 11:14 PM
Neptoess's Avatar
Neptoess
yeah before replacing the springs i'd try to make certain that they're the problem
Old Jul 27, 2009 | 09:07 AM
TexasGuy001's Avatar
TexasGuy001
I agree about the warped brakes being the cause. This is most likely the problem. If it really is the rear that is bouncing pretty bad, then the drums need to be turned and get some new shoes. My truck did this for a little while and that fixed it. Same thing with my friends Dodge.
