Rearend
Old Jul 26, 2009 | 10:59 AM
Stroker 94 1/2's Avatar
Stroker 94 1/2
Rearend
Hey guys I went to a track last night and got to see what my truck would
do and it wasn't good. I only got 1 tire to going and I spun it 1/4 of the
way down the track till it finally grabed and then she took off. My time
was a 19.6367 at 84.76mph. The dodge I went against did 16.6519 at
81.04mph. Will changing the rearend fluid to some royal purple with the
friction modifier help to make it kick in or is it something else? I have
77,500 on it and I bought it with 50,000 and I don't know if the previous
owner had changed it. I know it needs changed but if I need to change
something else I only want to be in there one time because funds are a
little short right now.
Old Jul 26, 2009 | 11:18 AM
redfire42's Avatar
redfire42
put a locker in it.
Old Jul 26, 2009 | 11:24 AM
SuperDoodie's Avatar
SuperDoodie
Do you know if yours is a limit slip? Not all of them came with one..
There is a tag on the rear end. You should see something with L/S on it.
If not, then get a Eaton True Trac. They work very well
Old Jul 26, 2009 | 11:35 AM
Izzy351's Avatar
Izzy351
Too much friction modifier will make it act more like an open diff if it is limited slip. I put royal purple in mine and so far so good. I haven't tried taking off with it to see if it spins both just yet... Might have to try that today.
Old Jul 26, 2009 | 11:48 AM
Stroker 94 1/2
Ya i pretty sure its a Ls373. The door axle code is c1 and the tag on the diff says L73.
Old Jul 26, 2009 | 12:06 PM
Stroker 94 1/2
I have read that I need to get 75w-140, but how much do I need to get to refill the diff?
Old Jul 26, 2009 | 12:20 PM
SpringerPop's Avatar
SpringerPop
6.9 pints, (or 3-1/2 qts) 75W-140 SYNTHETIC gear oil.
If you have a limited slip rear differential you also need 8 ounces of "Additive Friction Modifier C8AZ-19B546-A" from Ford.
Pop
Old Jul 26, 2009 | 12:52 PM
mechelement's Avatar
mechelement
With a LS rear end you have to use the fully synthetic 75W-140 gear oil. The only stuff I could find already had that the slip additive in it. I bought a 4oz bottle of slip additive from Ford just in case.
I couldn't get the claimed 3.5 quarts of gear oil in the rear diff when I filled it the first time. After I drove it and everything got warm, I was able to fit the remaining 1/2 quart. I had to add a little slip additive. I still have to add a little bit more.
Old Jul 26, 2009 | 01:21 PM
BDalton's Avatar
BDalton
Maybe stickier tires would help?
Old Jul 26, 2009 | 01:24 PM
preppypyro's Avatar
preppypyro
No one mentioned worn out clutch packs in the diff, that could be a possibility also.
Old Jul 26, 2009 | 10:37 PM
Stroker 94 1/2
Thanks for the help guys. I have been trying to find royal purple 75w-140 around here
but no body has it. Anybody use mobile 1? Does it already have the friction modifier in
it? I wondered if the clutches were bad but would a fluid change make a difference and
it start to work again?
Old Jul 28, 2009 | 11:29 PM
Stroker 94 1/2
Well I did a fluid change on monday night and this afternoon I got both tires to hook
up. Just wanted to put a post up that the fluid did do the job. Thanks for the help once
again.
Old Jul 28, 2009 | 11:35 PM
Izzy351's Avatar
Izzy351
Yep -- worn out fluid will cause slippage... Glad you got it fixed!!
Old Jul 28, 2009 | 11:37 PM
Stroker 94 1/2
Ya now I'm ready to go get that dodge that I went against at the track.
Old Jul 29, 2009 | 08:32 AM
RedBoat's Avatar
RedBoat
Rather Be Floatin
Damn now I have worn out fluid!! Looks like I need to get me 4 qts. Royal Purple. Am I correct that I dont need the friction modifier with the royal purple. Sorry about the hijack!
