You seen my 5 inch MBRP rolled edge tips Jeremy. I think 5 inch would be sufficiant with your 4 inch piping, 6 maybe but above would look kinda wierd sticking out of there with just your 4 inch exhaust, IMO. BDrummonds Brandon had some nice straight edge tips with his duals before he went to stacks, they might still be in his gallery, give a look see.
Hey Mike I have 5" piping not 4". Thats why I want a 6" tip.
And whats the differnce between a dual wall or single wall?
It's just as the name implies. A single wall tip has one layer of piping and a "rolled" tip so that it has a nice rounded edge to it. A double walled tip is basically a pipe within a pipe. The double walled tip will last longer before any discoloration since the inner wall will absorb a majority of the heat. That way the double walled tip will stay bright and shiny for a long time (notwithstanding the soot).
I think the MKO tip just because its $65 and its 20" long (5"into 6"). Then I can make it come out at more of an angle then just sraight out the side witch I am not a fan of.
