need help please
Old Sep 24, 2009 | 09:53 PM
shan69743's Avatar
shan69743
sorry for so long but here is an update. replaced the fuel pump and starter truck runs. brake lights gave me some problem. used a multimeter and wasnt gettin voltage at the light or at the brake switch so i just wired it into my fuse box, brake lights work great. so as of right now its road worthy, with the few exceptions.
1st i was told i was missing a smog pump, i dont know a whole lot about these fill me in.
2nd it doesnt have a catilytic converter does it need one?
any info on either of these would be great. thanks guys.
Old Sep 24, 2009 | 11:04 PM
bren_tx's Avatar
bren_tx
smog pump pumps air into the catalytic converter to help it operate better. since you dont have one why have the other.
no you dont need them unless the area you live in does visual, emissions testing.
Old Sep 24, 2009 | 11:10 PM
shan69743's Avatar
shan69743
Is Utah one of those states specifically the north salt lake valley?
Old Sep 24, 2009 | 11:15 PM
kc0rey's Avatar
kc0rey
Never mind...I figured it out!
Old Sep 25, 2009 | 05:24 AM
Djack04F150XL's Avatar
Djack04F150XL
Timbersteel, Sorry for the late update but I found that the ground wire at the battery terminal had dropped off and it fried the wire to the EGR vacuum switch. It had to get a ground somewhere, so that ended up frying the ECU. After I replaced the ECU and replacing the ground at the battery( black/green wire in the harness) the truck ran. I then had to remove the fuel tank which was a total loss because of rust. Replaced with a new Dorman tank and the fuelpump/gauge unit. Also had to bypass the tank diverter valve because it leaked fuel. Truck runs good now.
98F150on33s
1997 - 2003 F150
Nov 26, 2014 11:28 AM
ManfredVonRichtofen
1978 - 1996 Big Bronco
Apr 25, 2013 11:49 AM
BuckHammer
55
Jan 31, 2011 12:59 AM
05on20s
Jan 25, 2011 07:43 AM
East TX Tim
Nov 11, 2010 12:28 AM
