I find it easier to open two browsers. One with my photobucket page, and the other here. I then just bring up the photo on photobucket in the larger frame, and copy and paste. The copy and paste only works if you select the "post reply" and don't use the quick reply I am using now. It is the easiest way to do it, that I have found. You can also copy the "img" code in the photobucket file. When you scroll over your pictures, a box appears that has 4 or 5 options in it. The "img" code is the one you want. It will copy the coded text that you can insert anywhere on here, and after you post the message, it will display a picture. I haven't used it for my gallery, just for inserting pictures in forum posts. I linked my photobucket in my signature.
Is that the house, or the shop in the pictures? Add some old Fords, and you're all set. Now, click on one of the pictures, to expand it in the screen, and just copy and paste, using the functions when you right click the mouse. Make sure to use the "post reply" button and not the quick reply box.
