New Flywheel
Old Jul 25, 2009 | 09:43 AM
Passin Thru's Avatar
Passin Thru
New Flywheel
Changing the flywheel in an automatic. Anything I need to know before I start? How long should it take and what's the worst thing to expect? I am an aircraft mech. Thanks
Old Jul 27, 2009 | 08:26 PM
Passin Thru
GOSH! So many answers to choose from.
Old Jul 27, 2009 | 08:54 PM
DAVID'S97F250HD's Avatar
DAVID'S97F250HD
2wd......Pretty straight forward, remove the driveshaft, pull the starter, then the inspection cover, remove the torque converter bolts, remove the cooler lines, unplug your shift selector and remove the cable, support the tranny and remove the tranny bolts.
If its a 4wd, I splitted the transfercase from my tranny to lighten it up.
If your muscling these things in you absolutly need a friend maybe even a 3rd person to come down, both the tranny and transfer case are heavy by themselves. Bolted together I can not see it going in 1 piece with out the aid of a tranny jack unless your superman.
Old Jul 27, 2009 | 08:55 PM
DAVID'S97F250HD
oh, dont forget the dipstick tube like I did.
Also, I would consider replacing the seal behind the torque converter and update the bushing that handle a little more heat and has improved drain back properties.
Old Jul 27, 2009 | 10:36 PM
Passin Thru
OK Thanks and Kudos for telling me about the dipstick tube.
Will use jack as I already have bad back and 2 surgeries.
Baseball is 90% mental,the other half is physical. Yogi Berra
Old Jul 27, 2009 | 10:38 PM
Passin Thru
Oh it is 4X4 also.
85 xlt lariat
Sep 30, 2012 01:01 PM
samuelalynch
Jun 17, 2011 01:43 PM
foggy_2
Apr 25, 2002 02:42 AM
