Sponsored by: Real Truck
water in fuel message.
Old Jul 24, 2009 | 11:55 PM
99whiteford's Avatar
99whiteford
On my 06 F350 whenever it gets below a quarter tank of fuel I get a water in fuel message on dash.I can put fuel in it and message will leave. and stay off until i get back to quarter tank.
If I change the fuel filters will this cure my problem or do i have water in my fuel tank.
Old Jul 25, 2009 | 01:43 PM
06silvercrew's Avatar
06silvercrew
The HFCM (pump.filter assembly on the frame) is where the sensor is. You can just pull it out and clean it, it just pulls out with plyers. Mine was all gummed up, I replaced it because I had already bought one but it could have been cleaned I think. Worth a shot only takes a few mins. If not a new sensor is only like $20
Old Jul 25, 2009 | 02:41 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
Have you tried draining the water sep on the frame rail? Or is it just that you only drain diesel when you try to get the water out?
Old Jul 25, 2009 | 05:27 PM
jar06896's Avatar
jar06896
I've had a similar problem in my '06 6.0. I've drained the frame filter assembly twice. My mechanic reccommended pulling the filter and plug out, then spraying carb cleaner through the assembly to clean out any potential contaminants. Replace the filter and flush with clean fuel. That sensor cna be really sensitive.
Old Jul 25, 2009 | 07:15 PM
senix's Avatar
senix
moral is change the fuel filters and drain the fuel/water separater monthly
Old Jul 25, 2009 | 08:45 PM
06silvercrew
Just be sure to pup the sensor out too otherwise you wont get it all out.
Old Jul 25, 2009 | 11:43 PM
99whiteford
Drained seperator today and had some water in it.just purchased this truck about a week ago and plan on doing a full sevice in the next few days.On my 99 I only changed fuel filter once a year.Is this okay for the 6.0.this truck is not a daily driver.It will be used manily to pull camper.I will probably average less than 6k a year on it.
Also I'm very picky about where I'll get my fuel.
Old Jul 26, 2009 | 05:44 AM
senix's Avatar
senix
Then once a year should be fine.
Old Jul 26, 2009 | 08:43 AM
GQCOWBOY's Avatar
GQCOWBOY
chg filter now not starting
I have a probem, chg my rail filter, drove it for an hour or so,
made it home park the truck. Came back to start it and it turned over, but didn't start. I checked to line to make sure that fuel was getting to the top filter no problem. A friend told me I might have air in it...
How do you get the air out if that is the problem?
truck is an 03 F350 6.0 diesel...Help...
Old Jul 26, 2009 | 08:47 AM
senix's Avatar
senix
on my 6.4 I have to hold down the fuel shutoff to get it prime. Might give that a shot.
Old Jul 26, 2009 | 08:59 AM
GQCOWBOY's Avatar
GQCOWBOY
Old Jul 26, 2009 | 09:34 AM
GQCOWBOY's Avatar
GQCOWBOY
Thanks
Location on that fuel shutoff? I'm new to the diesel world, my first one.
Old Jul 26, 2009 | 09:39 AM
senix's Avatar
senix
Check your owners manual. Mine is on the passenger side, open the door and it is on the side of the dash that mates with the door.
Sometimes they are on the kick panel by the e-brake or on the passenger side kick panel.
Old Jul 26, 2009 | 10:12 AM
GQCOWBOY's Avatar
GQCOWBOY
Ok, I'll check thanks
Old Jul 26, 2009 | 12:38 PM
texastech_diesel
Token Redneck
On the 6.0 it should purge itself of air, it'll chug and put out some white smoke and idle really rough, but I'm almost 100% the manual says that's normal getting the air out of the common rails. And I don't think there's a fuel cutoff switch in the cab on our trucks either. I've seen them in cars, but I've never seen one in a Gen1 SD.
Flip the key into the On position and let the glow plug light go out, then let it just sit there until you hear the fuel pump shut off. Do that a few times, and try to crank it.
