I have a 76 f150 with the standard electrical problems under the dash. I am attempting to work through them systematically and am working simultaneously on the dash assy and the fuse block.
My fuse block is corroded at the terminal clips, has random fuses in it, and has very faded (unreadable) writing on it.
I'm asking if anyone can tell me what circuits each fuse serves? I have posted on the dentside thread w/o any luck. I also have searched here and on google and that was two more strikes.
I even have a factory manual on CD, and it IDs every fuse block except F series - figure that one out!
Any help would be deeply appreciated. The dash module is out, the fuse block is hanging, and she ain't moving till I figure this out.
I don't have a fuse legend for your truck. But do you have individual colored wires still leaving each fuse position? If so, you can look these up in the diagrams and see what each wire feeds.
Thanks for the tip! I did finally get a listing on the dentside forum. I will still use your tip as I track down my individual issues. Things are looking up!
