Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Help!!!
Old Aug 10, 2009 | 06:21 PM
Surrealpink's Avatar
Surrealpink
Exclamation Help!!!
Hi. I have a 2003 ford escape. A few days ago the daytime running lights, only, started flashing like strobe lights. Now I have a dead battery. Anyone know anything?
Old Aug 11, 2009 | 06:35 AM
DoctorCAD's Avatar
DoctorCAD
Sounds like a short somewhere in the DRL circuit.
Pull the DRL fuse and see if the battery stays charged.
Old Aug 15, 2009 | 02:21 PM
aquanaut20's Avatar
aquanaut20
Make sure your parking brake is completely disengaged.
One click up and the DRL should extinguish (shut off).
Report back....
Old Aug 15, 2009 | 08:04 PM
bmuhlbach's Avatar
bmuhlbach
welcome to the site.
Old Aug 17, 2009 | 01:06 PM
Surrealpink
Ok... I replaced the battery, tested it, and the alternator is keeping it charged... if I pull up the emergency brake one notch, it disengages the drl and I don't have issues. I pulled both fuses in the enfgines for the daytime running lights, and they look ok, put different ones in and it didn't make a difference, they are still flashing.
Old Aug 17, 2009 | 01:33 PM
wptski's Avatar
wptski
The DRL is operated by the DRL module and it may be telling it to flash! You would need a wiring diagram and a meter to diagnose the DRL module. Don't know if it's a seperate module or included into something bigger! I looked at a on-line manual and no relay is listed for the DRL either.
Old Aug 17, 2009 | 01:49 PM
Surrealpink
Thanks... there are 2 fuses in the engine fuse box, as well as a module under the dash inside the car... acording to my repair manual... I am just wondering if I should try and remove the module, take out the fuses, and then not have running lights anymore... or if there is a short... will it still short out with all that removed...
Old Aug 17, 2009 | 03:27 PM
aquanaut20's Avatar
aquanaut20
Ok.... if I pull up the emergency brake one notch, it disengages the drl and I don't have issues.
Does that mean they stay off? Before you go spending any more $$$ on parts, check the Hand brake circuit for chaffed wire , miss adjusted or defective switch
Old Aug 17, 2009 | 10:23 PM
wptski's Avatar
wptski
If you can get to the module, just disconnect the cable(s). If your worried about it shorting out, wrap it with electrical tape.
Didn't know that you had a repair manual!!
Larietpsd
2015 - 2020 F150
Apr 14, 2016 10:47 PM
fordguy98
Nov 30, 2015 08:56 PM
aparamburo
2004 - 2008 F150
Dec 15, 2012 09:52 AM
armour01
2004 - 2008 F150
Oct 16, 2012 02:11 AM
johnson2007
17
Oct 3, 2011 08:24 AM
