i asked this in the differental section but i need more info. i have a 2000 f350 v10 w/ 3.73 gears. i'm looking to install 4.30's or 4.56's. i've been looking for a place to get a decent deal. i'd like to give a sponsor buy buissness. can anyone point me in the right direction on where to buy? i do no off roading just light everyday use and towing my 9000lbs. camper. also am i correct do i have a dana 50(in the rear) w/ 10.5" ring gear, and whats the front diffs specs?thanks in advance.
-ed
Assuming a SRW the rear should be a Sterling 10.25/visteon 10.25, they take the same gears in any case. I use Motive gears predominantly, their Performance line is typically the same gear as OE (both are made by AAM and sold to motive and Ford/Chevy.) When I had a shop, we used National Driveline when I needed several gearsets, onezis was who had the cheaper shipping since they weight ~21lbs per set.
on a srw I believe D60 was the common axle.
If you're running 35s or 315s, then get the 4.56 or lower gears. I put in 4.56 and almost wish I had gone 4.88.
-ed
You have the Ford Visteon/Sterling 10.5 rear and the Dana 50 front. Ford switched to the Dana 60 fronts during the 2002 production.
