Sponsored by: Real Truck
diff gears.
Old Jul 23, 2009 | 06:13 PM
spinella's Avatar
spinella
diff gears.
i asked this in the differental section but i need more info. i have a 2000 f350 v10 w/ 3.73 gears. i'm looking to install 4.30's or 4.56's. i've been looking for a place to get a decent deal. i'd like to give a sponsor buy buissness. can anyone point me in the right direction on where to buy? i do no off roading just light everyday use and towing my 9000lbs. camper. also am i correct do i have a dana 50(in the rear) w/ 10.5" ring gear, and whats the front diffs specs?thanks in advance.
-ed
Old Jul 23, 2009 | 06:49 PM
ReAX's Avatar
ReAX
Assuming a SRW the rear should be a Sterling 10.25/visteon 10.25, they take the same gears in any case. I use Motive gears predominantly, their Performance line is typically the same gear as OE (both are made by AAM and sold to motive and Ford/Chevy.) When I had a shop, we used National Driveline when I needed several gearsets, onezis was who had the cheaper shipping since they weight ~21lbs per set.
on a srw I believe D60 was the common axle.
If you're running 35s or 315s, then get the 4.56 or lower gears. I put in 4.56 and almost wish I had gone 4.88.
Old Jul 23, 2009 | 06:50 PM
06silvercrew's Avatar
06silvercrew
No you have a ford rear end with 10.25/10.5 ring gear. Front should be a dana 50
Old Jul 23, 2009 | 06:52 PM
ReAX's Avatar
ReAX
Oh yes. You have the 3.73 carrier, so if you go with the 4.56 and don't want to replace the carrier you need the "thin" gear.
Did the later models get the 60? I thought for sure that I had a 60 upfront when I bought my parts.
Old Jul 23, 2009 | 06:53 PM
06silvercrew
You are correct, cant remember exact year but yes the early trucks had 50's later had 60's Wanting to say 02 was the switch but dont quote me on that.
Old Jul 23, 2009 | 09:50 PM
BadDogPSD's Avatar
BadDogPSD
-ed
You have the Ford Visteon/Sterling 10.5 rear and the Dana 50 front. Ford switched to the Dana 60 fronts during the 2002 production.
Saw these on another site-
http://www.thedieselstop.com/forums/...-gears-232460/
Old Jul 23, 2009 | 11:17 PM
spinella's Avatar
spinella
thanks guys,
i'll look into motive gears. are there any sponsors on FTE that sell gears?
Old Jul 24, 2009 | 12:55 AM
EXv10's Avatar
EXv10
This sounds correct to me.
Old Jul 24, 2009 | 01:59 AM
Furian's Avatar
Furian
You Keep What You Kill
Bronco Graveyard is a FTE sponsor...
Old Jul 24, 2009 | 05:17 AM
spinella's Avatar
spinella
thanks for the link. i'll give them a call.
