Modular V10 (6.8l)
Which Banks Header?
Old Jul 23, 2009 | 05:57 PM
Part-Timer's Avatar
Part-Timer
Which Banks Header?
Hi all,
I'm looking to put a set of Banks headers on my 2000 Ltd. Excursion and Banks lists 3 possible options:
<TABLE><TBODY><TR class=oddrow><TD>
Ford 6.8L Trk, W/egr Late Cat #49133
</TD><TD class=textcenter></TD><TD class=textcenter></TD></TR><TR class=evenrow><TD>
Ford 6.8L Trk, W/egr Erly Cat #49136
</TD><TD class=textcenter></TD><TD class=textcenter></TD></TR><TR class=oddrow><TD>
Ford 6.8L Trk No-Egr, Late Cat #49138
I assume that's its either #49133 or #49136, but I don't know the difference between the two. Can anyone tell me which is the one I should be looking to order?
Thanks,
Brian
</TD><TD class=textcenter></TD><TD class=textcenter></TD></TR></TBODY></TABLE>
Old Jul 23, 2009 | 07:47 PM
Monster-4's Avatar
Monster-4
I assume it has to do with which y-pipe you have. What I don't understand is it's possiable to have the earlier y-pipe and no EGR (like my 2000) but I don't see that as an option.
Old Jul 23, 2009 | 08:41 PM
dew the thunder's Avatar
dew the thunder
The cat was further back in the system on the 99s than it is on the 2000+. That might be what they mean by late/early cat.
Old Jul 23, 2009 | 08:54 PM
Monster-4's Avatar
Monster-4
Many 2000 also had the same y-pipe/cat combo the 1999's did. In 2000 there was a TSB that replaced the y-pipe/cat with the one that was on all 2001+ models if the owner complained of flutter. I know mine has the same y-pipe/cat as the 1999's had.
Old Jul 23, 2009 | 10:11 PM
Antelope V-10's Avatar
Antelope V-10
I think what they talk about is the Cat mount up flange with the factory y-pipe. Early is the mounting flange behind the cross member, late the mounting flange is in front of the cross member.
Old Jul 23, 2009 | 11:53 PM
Part-Timer's Avatar
Part-Timer
Thanks for the help everyone.
Antelope, I note in your sig that you've got a Trutrac limited slip. My Excursion is going in the shop next week to get a gear swap to 4.30's and I was thinking about having a Trutrac installed while the diff was apart. How do you like yours?
Brian
Old Jul 24, 2009 | 07:22 AM
Antelope V-10
Trutrac, Love it. Money well spent. Have them put one in while they are in there.
51dueller
112
Jan 23, 2025 04:08 PM
DawnPatrol
May 4, 2013 09:21 AM
senix
6.4L Power Stroke Diesel
Jan 31, 2011 01:46 PM
morrisjl2
General Diesel Discussion
Apr 30, 2009 03:00 PM
Bowie
Nov 6, 2008 03:05 PM
