Are any of you guys running new radiators i think npd as them in your 48-50 trucks with a 226 i cant find any nice used ones so i might buy a new one the only thing is im afraid they look to modern since im going for an origanal restoration pictures would be great
well i dont have any radiator whatsoever so thats not an option ..and i dont want to pa a hundred bucks maybe for a used one and then have to get it recored also
Well..................... you should just buy me a shinny new modern looking aluminum one and I will send you my old original looking one, problem solved!
PS - I like your truck!
Reason: add P S
Check US Radiator http://www.usradiator.com/tford.htm I bought one from them a few years ago for my 51 and it looked just like orignal, and fit perfect.
I have the rad out of my 52 that came with a 6 cyl. I think its original. I am not going to use it. It seem in good shape. I could take some pics and send them to you. Maybe some of the other members could see it and make sure its the one.
did this truck have the flathead or the ohv motor or did they use the same radiator pics would be nicee
It would of had a ohv 6.When i got the truck there was a 302 in it with this rad hooked up to it. I took some pics but cant find my cable to hook my camra up to my computer. My sun has it someplace and he will be home from work later tonight.i will post some pics then. The only prolem with the rad is the lower brace is rust out.Would be a easy fix.
