Flaring stainless brake lines
Old Jul 24, 2009 | 10:48 AM
DROPTOP46's Avatar
DROPTOP46
Be carefull, as you want to make a 37 degree single flare. Check out Pure Choice Motorsports, they have a variety of flaring tools and fittings. Buy a good one, it's worth it.
Old Jul 24, 2009 | 02:06 PM
harley f150's Avatar
harley f150
Droptop
It was my understanding that you should only use 37 degree if you are hooking to AN fittings. If hooking to standard brake fittings you should use 45 degree double flare. Otherwise they don't seal properly.
Old Jul 24, 2009 | 03:32 PM
DROPTOP46's Avatar
DROPTOP46
OK, stainless is too brittle to double flair. So, it is done with a single 37.5 degree flare, and special fittings. The flare is protected by a sleave, and then a flare-nut is used to tighten it. "standard" brake fittings ARE 45 deg, and DO require a double flare to properly seal with a 'steel' line. So, to use stainless, you will need to adapt all fittings to 37 deg., or "A.N." . These fittings are available from Earls, Goodridge, and many others. I generally use Earls, or deal with Pure Choice. Oh, one more thing, There is some question as to whether or not stainless brake line is DOT leagle, and I have been an expert witness in an insurance case where-in the use of aftermarket stainless steel brake lines was part of the outcome, - not in the car builders favor. Yes, I use stainless on high end show cars, but I prefer steel on performance/driver builds.
Old Jul 25, 2009 | 02:00 AM
nordvik72's Avatar
nordvik72
http://www.summitracing.com/parts/SUM-220237/
these are the flare nuts i got and all it says is inverted flare. when i googled inverted flare all that popped up was 45 deg flares so who knows ill do some more reasearch
Old Jul 25, 2009 | 11:25 AM
DROPTOP46's Avatar
DROPTOP46
I took a look at those and they sure look like the hardware for 45 deg. double flares. check out www.earlsplumbing.com . 3/16" is = to #3, and 1/4" is = to #4AN
cadunkle
May 24, 2017 02:24 PM
fasthauler
Jan 1, 2017 11:11 AM
49fordv8f4
26
Mar 27, 2016 10:29 AM
GreenMtnMan
Nov 15, 2015 05:22 PM
MikeS29
May 7, 2011 03:57 PM
