Replacing Manifold Gasket RH side...
Old Jul 23, 2009 | 02:25 PM
96F350Beast's Avatar
96F350Beast
I need to replace the manifold gasket on the right hand side (pass side). I took it to an exhaust place and they said a minimum of $400. Does that sound right? How hard of a job would it be to do myslef? I am by no means a mechanic. Is the job simple enough to do in my driveway with no lift? Any input would be great before I go drop 400. The guy said there was a valve that needed to be replace also. EGR valve I think he said.
Old Jul 23, 2009 | 02:43 PM
Old93junk's Avatar
Old93junk
Has someone else replaced the manifold previously?......Stock they will not have gaskets.
If you are not mechanically inclined, I would get some more estimates........If you are brave enough to want to attempt it, we can talk you through it.....EGR valves are simple R&R jobs.
Old Jul 23, 2009 | 07:40 PM
96F350Beast
I got another quote from a mom and pop shop and they said $150 - $200. I think I'll give them a shot.I think my cat is clogged up also. When I rev the engine in park it sounds normal. when I rev the engine in gear it sounds like a go cart.
muddyforeman
Modular V10 (6.8l)
May 1, 2014 12:37 AM
pumpdriver20
Nov 20, 2012 12:30 PM
Regg_65
Jan 19, 2009 07:32 PM
fordtruckinsml
Sep 29, 2004 01:48 PM
billrigsby
Aug 17, 2003 08:40 AM
