Modular V10 (6.8l)
2V V10 changes
Old Jul 23, 2009 | 11:15 AM
sphinx's Avatar
sphinx
2V V10 changes
Can anyone tell me what changed over the years before the 3V came out?
Old Jul 23, 2009 | 01:29 PM
Destroya's Avatar
Destroya
'99 had the crappy heads and EGR.
'00 up to '04 had PI heads that gave more power. No EGR.
'04 ??? More spark plug threads.
'05+ 3v.
Old Jul 23, 2009 | 02:35 PM
sphinx's Avatar
sphinx
are the intakes the same from 99' to 04'
Old Jul 23, 2009 | 03:52 PM
Destroya's Avatar
Destroya
Intakes are not the same from '99-04.
They are from '97-'99 and then '00-'04.
The shape of the intake runners on PI heads changed in '00 so a pre-'00 intake will not fit '00 and above.
Old Jul 23, 2009 | 05:21 PM
Ricohman's Avatar
Ricohman
'05+ 3v.
Why are the 99' heads crappy?
Anything I should be worried about on my 99'?
Old Jul 23, 2009 | 05:26 PM
Monster-4's Avatar
Monster-4
No. They are not the "PI" (performance improved) version but other then not producing as much power they are not any worse.
Old Jul 23, 2009 | 05:48 PM
Destroya's Avatar
Destroya
They are prone to pop plugs as are some of the PI heads, not to mention nearly 50hp and 20ft.lbs less torque.
Old Jul 24, 2009 | 10:08 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
For the spark plug thread issues:
December 1996 - 4.6L 4V alignment feature added
February 1997 - 4.6L 2V head alignment feature added
September 2000 - WEP (Windsor Engine Plant) 2V head alignment feature modified (4.6/5.4/6.8)
November 2002 - WEP introduced long thread heads on 2V (all)
May 2003 - REP (Romeo Engine Plant) introduced long-thread heads on 4V 4.6 and 5.4
November 2003 - REP introduced long-thread heads on 2V and modified alignment feature
In 1999, and 2001, an interim fix was done for a cross-threading issue.
Original process:
Step 1 - Zero torque spark plug (air tool)
Step 2 - Torque to 16-20Nm final torque (DC Run down), monitor at 6-12Nm, and final torque must be reached within 0-360 degrees.
New process (addressed the possibility of applying installation torque for more than 25 degrees of rotation)
Step 2 - Torque to 16-20Nm final torque (DC Run down) start monitor at 6-12Nm, and final torque must be reached within 3-25 degrees.
Another action to address cross-threading was the addition of an alignment feature to lead the plug into the hole.
