Oil & Lubrication
Valvoline
Old Dec 2, 2002 | 08:26 PM
John with beastly 302's Avatar
Valvoline
I've been a loyal buyer of castrol Gtx for the life of my vehical. I will continue to buy castrol. I have a question about valvoline. If it Causes sludge in your engine then why doese it say #1 Choice of ASI mechanics.
Another question about motor oil. Doese castrol cause sludge or is that just a myth. Im going to rebuild my 1945 9n ford tractor. It has a straight four. I want to break it in on dino then switch to A full synthectic. Which brand will benifit me the most. (I'm going to work the engine hard.!!!!!)
Old Dec 2, 2002 | 08:56 PM
2fords2's Avatar
2fords2
Valvoline
I suspect that sludge is more a result of engines than a particular brand of oil, or possibly leaving an oil in an engine far too long. The only company to struggle lately with an engine sludging problem is Toyota with a select few of their V6 and 4 cyl engines. They initially blamed poor owner maintenance, but that was hard to believe because it implied that since they were the only company with such a public problem, Toyota buyers as a group were more prone to poor maintenance habits than other car buyers in general. Yeah, right. If you're happpy with Castrol, stick with it. It's a decent oil. Other good dino oils are Penzoil & Chevron. Plain old Mobil Drive Clean contains a lot of detergent additives, and my local Toyota dealer for one, claims it is the oem supplier of "toyota" brand oil. Who knows!
Old Dec 2, 2002 | 09:55 PM
Valvoline
Thanks for the info. I'll stick with castrol my family has used it since early 1900's. Hey check this site out!!!!
http://www.castrolhdl.com/
Old Dec 2, 2002 | 10:31 PM
Quadiquizm's Avatar
Quadiquizm
Valvoline
I like valvoline - seems to work OK for me.
Keep it Rubber Side Down!
Old Dec 5, 2002 | 02:04 AM
poopey's Avatar
poopey
Valvoline
Its Quakerstate and pennzoil dino that has been linked to sludging,valvoline and castrol actually have a good resistance to sludging according to mechanics and engine builders.
Old Dec 7, 2002 | 10:47 PM
Quadiquizm's Avatar
Quadiquizm
Valvoline
Penzoil has too many degergents for my liking - the stuff froths up like crazy!
Quaker State was good oil at one time.
I'll stick with Valvoline - it works for me and I know quite a few mechanics who swear by it.
Old Dec 7, 2002 | 11:27 PM
rgiles's Avatar
rgiles
Valvoline
I think any SL rated oil is going to perform well as it relates to not sludging and if you change it every 3000 I doubt any high grade oil will sludge (including Penzoil/Quaker State). I have also read about some Toyota's having engine sludge and it appears to be because of shearing of the oil. This is a good test case because from what I've read those that ran a good synthetic weren't having the sludging problem. Also those that changed it at 3000 or less didn't have the problem from what I've heard. I'm experimenting with using M1 in my Toyota Camry and will run analysis at around 5k miles to see how it's holding up. I might just test it at 3k to see if I should run it to 5000.
Old Dec 8, 2002 | 12:34 AM
poopey's Avatar
poopey
Valvoline
I`ve heard and read that valvoline all-climate and castrol GTX are better than most dinos in the area of shear-stable viscosity improvers.That is desirable if you are going to use a non-synth oil.:-)
Old Dec 8, 2002 | 09:36 AM
Matt_W's Avatar
Matt_W
Valvoline
Correct me if im wrong but i think Penzoil containes the additive PTFE which is basically little pieces of teflon. I used to use Penzoil until i heard this. It rare cases it can build up and clog your oil filter and can sometimes be found after you drain the oil in the motor. This never happened to me so im not sure but personally i use valvoline which everyone tells me good things about. (max life in my 3.8 chrysler with 150000 miles and not the slightest leak or sludge build up, and in my ranger 2.8 also with more than 150000 miles and no leaks.) As for my toyota V6 i havent noticed any sludge in it but it only has 50000 miles. I have the toyota dealer change my oil because they do it for free for the life of the car (pretty sweet deal huh?) but the motor does like a very thin oil. maybe the sludge is caused by putting in a oil that is too heavy. And since i told about all my cars i wont leave out my 67'bronco with a freshly rebuilt 289 which i put in valvoline but i am thinking of switching to synthetic because it isnt run very much.
Old Dec 8, 2002 | 10:15 AM
Paarrothead's Avatar
Paarrothead
Valvoline
I don't know if that teflon story is accurate. Because it can plug oil passages and potentially cause engine damage, DuPont (who makes teflon) supposedly prohibits its sale and promotion for use as an oil supplement. DuPont also says that teflon used as an oil additive is completely worthless.
I know that Fram used to sell oil filters pre-charged with teflon particles and they've been discontinued for some time now.
Like Robin Williams once asked, "If nothing sticks to Teflon, how can it stick to a frying pan?"
Old Dec 8, 2002 | 02:12 PM
horsepuller's Avatar
horsepuller
FTE Leadership Emeritus
FTE Emeritus
Valvoline
I don't think Pennzoil or any other reputable manufacturer ever put PTFE in their oil. PTFE was mostly hawked as an additive. Pennzoil's proprietary anti-wear component was Z-7, which probably used zinc.
Old Dec 8, 2002 | 02:23 PM
flyboy2610's Avatar
flyboy2610
Valvoline
One other thing to watch out for in an oil is the viscosity spread. 30 or more points can lead to sludge build up as the polymers break down. That's why many engine warranties are voided if 10W-40 is used. 20W-50 doesn't seem to have such a problem as the base oil is thicker to begin with. Stay with a viscosity spread of 25 points or less.
Old Dec 8, 2002 | 11:51 PM
rgiles's Avatar
rgiles
Valvoline
Cowboy_351
Oil & Lubrication
27
Oct 20, 2008 11:23 AM
grbr95
Oil & Lubrication
Oct 15, 2005 12:19 AM
grbr95
Oil & Lubrication
18
Aug 8, 2005 02:49 PM
BigShelby
Oil & Lubrication
17
Jan 23, 2004 05:54 PM
BigMattXXL
Modular V8 (4.6L, 5.4L)
Aug 30, 2002 06:37 AM
