Modular V10 (6.8l)
05 3v exhaust stud broken
Old Jul 22, 2009 | 08:40 PM
Ubbzy's Avatar
Ubbzy
Lookin under the hood tonight and I see the nut on the driver front cyl is not sitting on the manifold. I reach in and grab it and it comes right out. Busted off in the head. I could be wrong but I thought this was not a problem on the 05 3v's?
Old Jul 23, 2009 | 12:22 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Wow. Haven't heard of any of the 3-valvers with this problem. And with the exhaust manifold on the 3-valvers not being a "log", I woulda thought they could expand and contract without pulling too much on the studs. Guess not.
Old Jul 23, 2009 | 07:09 PM
dd6464's Avatar
dd6464
had to replace studs on my '05 3v at about 80k. it's a much bigger PITA on the newer coil spring suspension trucks than on the older 2v leaf spring 4wd trucks.
Old Jul 23, 2009 | 08:55 PM
BareBones's Avatar
BareBones
Damn......
Old Jul 23, 2009 | 10:04 PM
Ricohman's Avatar
Ricohman
Yup. The coil bucket is right in the way.
Old Jul 24, 2009 | 06:11 PM
BareBones's Avatar
BareBones
Looks like I may have to change more than the plugs at 50,000.
Old Jul 25, 2009 | 05:42 PM
nmocean's Avatar
nmocean
My step brother just looked at his and he has 3 broken it is an 05 5.4
Old Jul 25, 2009 | 08:56 PM
Ubbzy's Avatar
Ubbzy
Well I replaced the broken stud today. And yes the spring tower is in the way, but it was the front cylinder on the drivers side so not to bad.
There was no way for me to see where I was going to be drilling so using the picture above and a 12mm bolt cut down to a little over a 1/2in I drilled an offset hole to use it as a drill guide. I had to put a little weld on the 12mm bolt and tapped it into the oversized mounting hole in the manifold for a snug fit. then I clocked it to the position the stud was offset in the hole. I had to disconnect the steering shaft to gain just enough clearance to get an air drill in there. Once the hole was drilled in the stud extraction with an ez-out was.....EZ.
Old Jul 25, 2009 | 09:05 PM
Ricohman's Avatar
Ricohman
Nice job!
I wonder if these busted studs could all be done this way?
SteveBricks
S. California Chapter
653
Jul 13, 2021 11:13 PM
FuelishPleasure
Nov 9, 2010 10:48 AM
f-150 on 22's
2004 - 2008 F150
13
Oct 30, 2009 05:06 PM
HogTied
Jul 21, 2009 08:20 PM
inlandsurf
Jan 20, 2009 10:29 PM
