Higher Highboy
Old Jul 22, 2009 | 03:45 PM
Beer-Pancakes's Avatar
Beer-Pancakes
Higher Highboy
I just got a 77 F-250 4x4 Highboy and wanted to put 35" tires on it. I was told it needs a 4" lift to fit. 1st qustion: is that true, and 2nd, what is a good lift to put on.
thanx, BP
Old Jul 22, 2009 | 03:49 PM
montana_highboy's Avatar
montana_highboy
A highboy can easily clear 35's in stock form.
Old Jul 22, 2009 | 04:43 PM
ShamelessMT's Avatar
ShamelessMT
Your truck may or may not be a "highboy" due to the fact that it's a '77 and that's the year they changed the frame/suspension. Does it have a divorced transfer case? If so, it is one and yes, 35's will fit stock. Heck, I run 37's on mine with stock suspension. However, if you have the newer version '77 you will need those 4" of lift.
Old Jul 22, 2009 | 04:51 PM
ford1977owner's Avatar
ford1977owner
looks like everyone beat me to it but yes if its a true highboy you would be able to fit 35s without the 4" lift. but like they said if its not then yes u will need the lift
Old Jul 22, 2009 | 04:54 PM
ford1977owner
also for lifts get this link out its rough county
http://www.roughcountry.com/suspensi...0_77-79_4.html
Old Jul 22, 2009 | 07:28 PM
bigdavesohc's Avatar
bigdavesohc
That site does not have anything for the highboy, just later models.
Old Jul 22, 2009 | 08:53 PM
76f350spercamprspeal's Avatar
Hiboy is a Ford truck that came from the factory as having the following:
- Built from 1967 thru 1977.5.
- F-250.
- 4x4.
- Divorced transfer case.
Trucks that are NOT considered a Hiboy are:
- Any truck built after mid-1977. It goes by Consecutive Build Number in the VIN# anything built starting Y80001 is a 77 1/2. **
- Anything other than an F-250.
Old Jul 22, 2009 | 09:29 PM
bigdavesohc
Do we have to go through this again...
Old Jul 22, 2009 | 09:35 PM
What are you talking about?
And,no we don't...
Old Jul 22, 2009 | 09:37 PM
Holiver31's Avatar
Holiver31
Old Jul 22, 2009 | 10:20 PM
bucks77ford's Avatar
bucks77ford
I know the term Highboy is explained in the "Read First" thread, but maybe it should just be a sticky thread of it's own so we don't have to go through this again.
Old Jul 22, 2009 | 10:24 PM
We don't need to go through anything...
We will just have to wait and see if his truck is a HiBoy.
Old Jul 24, 2009 | 03:29 PM
Beer-Pancakes
- F-250.
- 4x4.
OK, my VIN does Not start with the Y80001..., but I'm new to this whole Ford Highboy thing, I may sound stupid but, how do you tell if it has a divorced transfer case?
Old Jul 24, 2009 | 03:32 PM
75F350's Avatar
75F350
A divorced transfer case is not connected directly to the transmission. The divorced or "remote mount" unit will have a driveshaft that connects the trans to the t-case.
Three driveshafts total in a truck with a divorced transfer case.
Old Jul 24, 2009 | 03:57 PM
Beer-Pancakes
OK, check, it does have a divorced transer case. So it is a "highboy", Sweet.
It only has 9.5/16.5's on it now, which I think = a 29" or 30" tire. I have checked around and I can get 35x12.5R16.5 BFG AT's or should I get 16 rims and tires?
ps, how do you post pics on here?
