Don't ask me, I just know it works. That's how I put the headers on my 460 ten years ago. Now, its done its fair share of sitting, but I abuse it when I run it. And when you walk in front of the truck all you hear is the fan spinning, no leaks. And I used it to install a manifold on my daily driven Bronco. Drove it for 7 years without any leaks. It's like Nike, Just Do It.
bbk's came in last week. hw and long gaskets included, but no donut gaskets. there is no donut gasket from the factory either, so i assume they aren't needed. also, is the header hw good enough, or should i use oem hw?
ok, i just checked the hw. i have 16 bolts, 4 double ended studs, 4 nuts, 4 regular washers, and 4 lock washers. i assume i will need to buy the manifold to cat hw? im gonna order a new egr tube and adapter just in case the one on there gives us a problem. if they come off easy, ill return the new parts!
i have a friend doing the headers sunday while i am at my baseball games. i will try to have him take before and after pics.
